Remote start and CIS problem
Old Dec 27, 2009 | 06:25 PM
sonikaccord's Avatar
Default Remote start and CIS problem
I have a compustar CM3000v3 and a 92 accord. I connected the status output (CN2/2 blk) of the compustar the wires from the cis and neither of them bypasses the switch. What could be the problem?
BTW, Remote start works when I press the clutch
Old Dec 28, 2009 | 05:41 AM
fcm's Avatar
fcm
Old Fart
Default Re: Remote start and CIS problem
What "wires" of the CIS did you connect the CN2/2 black status lead to, [color]? 94
Old Dec 28, 2009 | 08:01 AM
I tried both, but neither seemed to work.
Old Dec 28, 2009 | 04:42 PM
fcm's Avatar
fcm
Old Fart
What color are the two leads at your CIS? 94
Old Dec 28, 2009 | 06:44 PM
blk/grn and blu/red
Old Dec 29, 2009 | 06:14 AM
fcm's Avatar
fcm
Old Fart
Have you tried unplugging the switch and then using a jumper to connect the two leads together, if it is the CIS you are at, the car will start without stepping on clutch.
If you confirm you have the CIS, [using the jumper] then the switch is not a "grounding" switch it is a "continuity" switch and you will need a relay, wired like this...
one lead paralleled to #30 of relay the other lead paralleled to #87 of relay, 12V+ constant to #85 of relay and the black status, [CN2/2] to #86 of the relay.
CIS will work normally but the relay will close the circuit when remote starting.
I do not have a wire guide for a 92 Accord so I can't say if the switch you are at is the CIS, most Honda/Acura CIS use a black and a black/blue lead and all the switch does is supply a ground to the starter relay so connecting the status lead to the starter relay side of the CIS, [blue/black] would work, however if the switch is a continuity switch that will not work, [switch does not supply a ground to starter relay].
So to confirm you have the CIS unplug it and install a jumper, if that works, install the relay, if not, you do not have the CIS. 94
Old Dec 29, 2009 | 08:12 AM
Ok when I jump the connector the starter relay fuse blows. Idk what else to do. O and without the plug connected, the car won't start so that must be the switch.
Old Dec 29, 2009 | 10:59 AM
fcm's Avatar
fcm
Old Fart
You are jumping between the two leads, [black/green and blue/red] connecting them together? 94
Old Dec 29, 2009 | 06:58 PM
Yes sir.
Old Dec 31, 2009 | 05:36 AM
fcm's Avatar
fcm
Old Fart
That is strange, the jumper is doing what the switch would do when you step on the clutch.
When exactly does the fuse blow...
As soon as you install the jumper?
As soon as you turn on the ign. switch?
As soon as you try and start the engine? 94
Old Jan 2, 2010 | 08:55 AM
As soon as I attempt to start the car with the jumper connected...It's done that twice so far.
Old Jan 2, 2010 | 10:46 AM
fcm's Avatar
fcm
Old Fart
What fuse and what size is it?
Sorry, I can not find any info on the CIS for a 92 Accord, the service manual does not show a CIS, it does show the NSS for automatic transmissions.
I am still looking. 94
Old Jan 2, 2010 | 01:24 PM
7.5A in the drivers kick. It's the starter relay fuse.
Old Jan 2, 2010 | 02:20 PM
fcm's Avatar
fcm
Old Fart
I should have asked, when fuse blows are you starting with the remote start or the key, or does it make a difference?
If it makes no difference^^^
Move the remote starter output lead from where it is now connected, to a point past the cars starter relay, disconnect status wire from CIS. 94
Old Jan 3, 2010 | 07:20 AM
I'm starting with the key...I can post a picture of the wiring diagram if you want.
Old Jan 3, 2010 | 08:48 AM
fcm's Avatar
fcm
Old Fart
If you have it post it, none of the ones I can find show the CIS.
Either way, wiring the remote start starter output past the starter relay will solve the problem, CIS bypass is not needed. 94
pdevilk
Audio / Security / Video
19
Feb 7, 2012 03:01 PM
smelldaOdaa
Jan 29, 2010 08:46 PM
blasterman87
Nov 11, 2009 05:10 PM
Skipper75
22
Mar 8, 2007 07:02 PM
xcathodex
34
Mar 1, 2003 03:42 PM
