main relay kill question
hi, I'm doing a main relay kill but I don't want to do a switch skill, how can I connect the main relay kill to my current alarm? It's a Viper 350 plus alarm
thanks
thanks
It would be better if there is a switch, [redundent].
If you want it on the alarm install a latching relay, [on PGM-FI Main Relay ground] and use an "EXT" output, [like trunk release] to latch the relay, it will "delatch" when ign. is turned off, [passive]. 94
If you use a switch, [on/off] you do not need the relays, and a small, [easley hidden] 1A switch can be used, if you still want it passive, [it automatically "arms"] the latching relay(s) is needed, but will not be as easy to hide as a 1A switch. 94
kwijibodavid
Jul 9, 2012 10:03 PM
xcathodex
Audio / Security / Video
34
Mar 1, 2003 03:42 PM
