Remote start
Old May 2, 2002 | 08:02 PM
04accordV6's Avatar
Default Remote start
I was just wondering if anyone know how to do remote start on a manual transmission car. I heard it can be done but the car will always have to be in neutral when turned off. How do you trick the clutch. Any help is appriciated...
Old May 3, 2002 | 08:23 PM
95CoupinIt's Avatar
Default Re: Remote start (95integraLS504)
what kind of system u trying to install? tell me that..and then email me for the info..
bjsguitar@aol.com
Old May 3, 2002 | 10:50 PM
B18C1 for fun's Avatar
To bypass the clutch is pretty simple. There will be two plugs with two wires each attached to the clutch assembly. The lower one is to cancel cruise control when activated. The upper one is for the clutch bypass when starting the car. Simply unplug that upper plug, strip both wires back and tie them together. Make sure it is a good connection because if these two wires come loose, then you cannot start the car until these two wires are connected again. Hope this helps.
Old May 6, 2002 | 07:02 AM
my2ndtool's Avatar
the last tip is right on but by law only cliffords can be put on standards pretty cool to the car dosent shut down till you exit the veh. and arm the alarm that way their is no chance of a bad start or running over a kid or somthing bad but not as cheep but safe
allm0torGSR
Audio / Security / Video
Jun 3, 2008 09:21 PM
besouza
13
Dec 4, 2005 02:38 PM
sauceja
14
Sep 6, 2005 12:21 PM
Toda Party
17
Dec 1, 2002 05:28 PM
TurBoXBirD16
Mar 5, 2002 09:10 AM
