rca cable question
Old May 18, 2003 | 07:43 PM
RedDelSol si's Avatar
Default rca cable question
Hey guys i have a question about hooking up my rcas. My HU only has one rca out and I'm hooking up a 4 channel amp for my speakers. my question is how would i hookup the 2 rcas. I know id need the y connectors, but how would i hook em up? LIke woul i hook it up so that its both white on one y connector to the white output and the 2 red to the red output, or just hook up the red and white on one y plug to the white output on the head unit and the red and white on the other to the red output? thanks guys.
Old May 18, 2003 | 08:38 PM
Xsi's Avatar
Xsi
Default Re: rca cable question (RedDelSol si)
Don't hook both channels of the same RCA to the same Y adapter, if you know what I mean.
Put the left channel of each RCA into one Y adapter and the right channel of each into the other
Old May 18, 2003 | 08:58 PM
dannyboi's Avatar
Does your amp have two seperate gains? if so you might be able to just use one set of RCAs.
Old May 19, 2003 | 01:46 PM
PetroGuyX's Avatar
run one set of rca's from your headunit and y it off at the back, not at the head unit, i couldnt understand if you knew that or not, and colors dont matter as long as you match them all up and understand which is left and which is right
Old May 19, 2003 | 05:38 PM
no i didnt know that, im still a system noob lol.which is left and right if i may ask? also what are the benfits of using only one set and ying at the amp? thanks
Old May 19, 2003 | 05:42 PM
PetroGuyX's Avatar
it doesnt matter what color you use for left or right just make sure when you plug the RCA's into the headunit that you use one color for right and use the same color for right on the amp, but if you're y'ing off it really shouldnt matter
Old May 19, 2003 | 06:00 PM
ok cool thanks for all the help im learning what i can through experience i just havent done the 4 channel yet with one rca out thing lol
Old May 20, 2003 | 10:28 PM
drumking15's Avatar
actaully it will matter....voltage will be stronger across the main line and will travel better to the spliting point in rear, plus its cheaper to buy 1 longer cable and 2 jumper cables than 2 long as cables in my mind...less wires = better...plus you can invest in some better wires more prone to resist noise etc...
Old May 21, 2003 | 07:17 PM
Default Re: (drumking15)
ok cool thanks for cearing it up. i have monster cable rcas that i took from my dads old setup. the cable is as thick as 8 gauge power wire. these badboys are no joke lol! but thanks for giving me a reason. also, will i notice a sound difference compared to say a HU that has 4 channels?
LoGaN-VanG
Audio / Security / Video
16
Jun 20, 2009 08:21 PM
Got_soy
Oct 22, 2006 11:33 AM
blazeone44
Mar 29, 2006 12:58 PM
shivern
Jan 15, 2005 05:43 AM
shivern
Jan 14, 2005 09:12 AM
