please help with wiring my system
Old Sep 4, 2002 | 09:14 PM
ajshades's Avatar
Default please help with wiring my system
i hooked up my system once and its worked find - i undid the wires again to cover my boxes in carpet and now I have distrotion and a whole lot of bad **** going on with my system....
*edit* ok after 2 hours working on my truck last night I found out that my problem is the power cable running from the battrey to the amp or its my amp
i undid the power cable (which was running through the firewall) and ran it straight from the battarie to the amp on the outside of the car
still there is a high pitch noise (when the car is off and worse when the car is running) through my speakers and my sub picks up all kinds of distortion coming from the head unit
but this is only when the power cable from the amp is attached
otherwise my componates speakers are fine
wtf is up with this???? do i need to buy a new cable or noise filter or is it my amp?
Old Sep 4, 2002 | 09:36 PM
ichibanjap's Avatar
Default Re: please help with wiring my system (ajshades)
Check your ground. Scrap the paint away from the metal and make sure it's on there good.
Old Sep 5, 2002 | 10:59 AM
ajshades's Avatar
its only when the power cable is attached to the amp - nothing else connected makes that noise - i tired all the cables seprately
Old Sep 6, 2002 | 07:37 PM
DB5000's Avatar
TheTealHatch
Audio / Security / Video
Aug 25, 2006 03:15 PM
A.E Motoring
Jun 28, 2005 05:11 PM
taffetawhitegsr
Jul 11, 2004 04:32 PM
ls-t del sol
Dec 16, 2003 11:38 AM
crxguy05sir
May 18, 2003 05:42 PM
