Amp power cable
Old Aug 28, 2010 | 04:42 PM
Yun_Ej2's Avatar
Default Amp power cable
Ok so I have a 94 civic dx and I can't find a hole in the firewall to feed the amp power cable. If you guys know of any let me know or take pictures if you can, thanks.
Old Aug 28, 2010 | 10:38 PM
DMP's Avatar
DMP
Default Re: Amp power cable
If you cant find a hole, make one. Just make sure youre not drilling through anything important. Install a grommet so the bare metal doesnt cut through the wire too.
Old Aug 28, 2010 | 11:56 PM
98civdx's Avatar
Master Detailer
Left side of your battery towards the bottom, there should be a spot there.
I hate drilling into anything if not required.
Old Aug 29, 2010 | 12:54 AM
royalaccord92's Avatar
You won't just see a hole. Look for a black grommet to push out or drill thru. Should be one behind the glovebox.
Old Aug 29, 2010 | 01:56 PM
Yun_Ej2's Avatar
I agree about the drilling! But I took that grommet out and theres no hole? Theres like something behind it.
Old Aug 29, 2010 | 03:24 PM
Cobb2819's Avatar
the "something behind it" i think is firewall pad, i just pushed it down and found it under the carpet. kinda tricky around there because of the heater and fan motor, but that little grommet is the best place.
Old Aug 29, 2010 | 04:11 PM
98civdx's Avatar
Master Detailer
This man speakes the truth.
What i did, was pass the wire in, and then look for it on it the side, it can be a little difficult.
Old Aug 30, 2010 | 03:02 PM
You could also cut a hole thru the firewall pad.
Old Aug 30, 2010 | 06:24 PM
ken9's Avatar
Take your A/c and you will have alots of space and room. Probably not the best in you live in Hot weather.
Old Aug 30, 2010 | 06:28 PM
98civdx's Avatar
Master Detailer
theres already plenty of space.
I was able to fit a 0 guage in, without taking anything out, and didnt have to cut the firewall mat, There is no reason to do that.
Old Sep 5, 2010 | 01:59 PM
tinctorus's Avatar
Make sure you use a GOOD grommet when you run it through the firewall if you are NOT running it through a rubber grommet, I have always used these or a variant of these with GREAT success, PLUS they are on sale right now for the Monster cabel ones and you get 2 of them where as other companies only give you 1
http://www.amazon.com/exec/obidos/AS...im/diymacom-20
Old Sep 5, 2010 | 02:37 PM
98civdx's Avatar
Master Detailer
Cut a hole in the stock one and pull the wire through, and your done.
I like to cut it a bit smaller so it is a tight fit.
Old Sep 11, 2010 | 06:13 PM
phantomdragon89's Avatar
I have a 95 Civic EX. My A/C doesn't work, so I just pulled the A/C drip hose out and ran my wire through there.
Dead CIVIC
Audio / Security / Video
20
Apr 22, 2013 08:33 AM
deerman2701
Jul 10, 2008 11:50 AM
Vistage
Sep 19, 2007 10:43 AM
crxguy05sir
May 18, 2003 05:42 PM
IDE RaiD
Aug 19, 2001 05:59 PM
