Radio not working Help!!
Old Apr 6, 2009 | 06:32 PM
fireblaze2k1's Avatar
Default Radio not working Help!!
The radio was working fine this morning, but I went over a speed bump and the speakers sounded like bad reception from a cd. I pulled out my deck and it got a little better, so I put it back in the console and thenthe music stopped coming from the speakers but the cd was still reading on the cd player. Dont know what to do.
Old Apr 6, 2009 | 07:15 PM
CIVICC2000's Avatar
Default Re: Radio not working Help!!
maybe the connetion, try it later, or the speaker's problem?
Old Apr 8, 2009 | 07:31 AM
dj-t's Avatar
You may have a ground out speaker line somewhere. unplug the harness from the radio and use a test light that has a ground indicator or a multimeter to check continuity to a ground source of each speaker wire to fine the grounded out line. It could be at the speaker itself of somewhere along the line.
Old Apr 8, 2009 | 09:42 AM
98civdx's Avatar
Master Detailer
most likey just a bad connection.
Old Apr 8, 2009 | 10:56 AM
Jturtle's Avatar
New User
x2 more than likely a speaker wire is grounding out on the frame or metal
Old Apr 9, 2009 | 06:36 PM
nope. checked my stereo with in the other car and the same result. The radio in myother car worked in my civic. I hit the radio and it game me static cd player. What should I do?
Old Apr 9, 2009 | 07:45 PM
dj-t's Avatar
Did you drive around and see if it cuts out with the new radio
Old Apr 9, 2009 | 08:40 PM
Jturtle's Avatar
New User
Old unit or faulty parts. Sounds like you blew the outputs on the cd player
VNG704
Jul 28, 2008 07:56 AM
eg2crx
Audio / Security / Video
Mar 9, 2007 02:20 PM
mxl36o
Oct 26, 2006 07:54 PM
rad_thundercat
Aug 23, 2002 10:21 PM
