CD player help!
Old Mar 9, 2007 | 02:04 PM
eg2crx's Avatar
Default CD player help!
I have had problems with my stereo in my car for about a month now, I dont get any power to my CD player at all, so i tried another CD player and I got the same result, so I checked all my fuses and none of them were blown. It started after i changed my battery, im not sure if i messed something up somehow when i did it, but this is bugging the hell out of me and I cant figure it out, if anybody has any idea of what it could be please help me out
thanks
Old Mar 9, 2007 | 02:19 PM
B18C_EJ8's Avatar
Since you didn't bother to tell us what kind of car you're working with, all we can do is assume that it's a Honda.
Did you check both fuses (under dash & under hood) for the raido? And by check, I mean verify as good with a meter or test light?
If the fuses are verified good, then your next step is to use your meter or test light to ensure you have constant 12v on the yellow wire to the deck, and switched 12v on the red wire. If those are good, then there may be a problem with the factory ground in the harness. Try another chassis ground. If the ground is good, then check all of the other wires for shorts.
Old Mar 9, 2007 | 02:20 PM
eg2crx's Avatar
Default Re: (B18C_EJ8)
Thanks, sorry about that, its a 94' del sol vtec
Danthemagicbum
Audio / Security / Video
May 22, 2010 07:02 AM
2drEG
Mar 12, 2008 03:11 PM
mrmcnotbuff
Feb 19, 2008 07:19 PM
EGgarniEG
May 30, 2007 02:02 PM
damion911
Mar 3, 2004 11:14 AM
