Radio Constant 12V Issues
Old May 18, 2007 | 09:09 AM
kinick313's Avatar
Default Radio IGN 12V Issues
Hey folks, I'm having some problems with my 98 Integra GSR Radio.
I was wiring my alarm system up, had no problems there, but I think I may have yanked out a 12V wire for my radio somewhere during the install (it was with remote start). I know its the 12V because I've yanked the radio and tested the 12V with a DMM and got 0V. I unbolted the fuse box to get to some wires easier, and I think the wire was yanked out somewhere Can anyone tell me what wire color I should be looking for and what color/size/shape/#connectors harness plug I should be looking for. Any other thoughts suggestions are appreciated. Thanks guys.
EDIT:
Ok, I'm an idiot... I'm having problems with the ignition wire. No 12V during key to ACC or ON, before OR after startup. Fuse is definitely fine, checked the yellow/red wire in the green plug at the fusebox and at the pins of the fuse. Constant 12V is fine, however it would seem that my head unit is wire incorrectly, and the red (12V) on the adapter harness goes to the yellow/red wire and the yellow (12V switched) goes to the constant 12V (white/blue) wire. Odd how it used to work and now it doesn't. Possible I fried a wire?
Modified by kinick313 at 2:31 AM 5/19/2007
Old May 18, 2007 | 11:29 AM
fcm's Avatar
fcm
Old Fart
Default Re: Radio IGN 12V Issues (kinick313)
If you have no 12V+ output from your ign. switch on acc., [yellow] you have a problem with the ign. switch. 94
Old May 18, 2007 | 05:26 PM
suspendedHatch's Avatar
No 12V at the ignition wire "after startup"?! Your car will not start up w/out 12v on that ignition wire. You're testing the wrong wire. You need the black/yellow 8 gauge wire on the ignition harness.
Your harness is wired correctly. Yellow/red is your radio accessory wire. My guess is that you blew the fuse, or that you're high on PCP.
Old May 23, 2007 | 07:58 AM
kinick313's Avatar
Default Re: Radio IGN 12V Issues (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">No 12V at the ignition wire "after startup"?! Your car will not start up w/out 12v on that ignition wire. You're testing the wrong wire. You need the black/yellow 8 gauge wire on the ignition harness.
Your harness is wired correctly. Yellow/red is your radio accessory wire. My guess is that you blew the fuse, or that you're high on PCP.</TD></TR></TABLE>
There is no 12V at the ignition wire to the radio. I'm talking about the switched 12 V at the radio harness. The fuse is fine, but when I hooked up the DMM to both the fuse's terminal, I didn't get any voltage at all. Any ideas?
My radio harness adaptor wasn't actually wired wrong, I just wasn't thinking right. Its hooked up right, I'm just not getting anything on the switched 12V wire.
Old May 23, 2007 | 11:18 AM
fcm's Avatar
fcm
Old Fart
OIC, the HUs acc wire, [switched], how about other accessories, do they all work, is there anything else that does not work?
Have you checked main fuses in the under hood fuse box? 94
Old May 24, 2007 | 10:41 PM
kinick313's Avatar
everything works... checked all underhood, everything is fine under there
Old May 25, 2007 | 05:42 AM
fcm's Avatar
fcm
Old Fart
Default Re: (kinick313)
If you have power at the radios acc. fuse, [fuse 28 - 10A] when ign. is in acc. or run, the problem is after the fuse, you may have "fried a wire", check all the plugs on the fuse box, make sure they are plugged in properly. 94
Old May 26, 2007 | 09:03 AM
kinick313's Avatar
sorry, i should have been more clear in my last post... no 12V at the fuse's pins underneath the dash when the ign is in acc or run. i meant the fuses are in working order... the problem is definitely before the fuse. all the plugs are in properly. any specific wires i should check upstream of the fusebox?
Old May 26, 2007 | 11:52 AM
fcm's Avatar
fcm
Old Fart
Have you got 12V+ on the ign. harness acc. lead, [yellow] when ign. is on acc. and/or run? If so, check ign. harness plug at fuse box. 94
ej888
Audio / Security / Video
Apr 19, 2011 11:35 AM
sz9182
Apr 30, 2007 08:27 PM
KrispyKreme
12
Mar 17, 2005 01:13 PM
Jonathan_ED3
Sep 5, 2002 10:12 AM
