Quick way to prevent theft
Old Nov 13, 2003 | 03:37 PM
  #26
4uhataz's Avatar
Default Re: (VTECorona)
And here is another. The A/C controls in my car have a total amp draw of 20. The fuel pump also has an amp draw of 20. Here is another. The hazard lights on my car draw 10 amps. The computer draws 10 amps. The cruise control draws 10 amps. The ignition draws 10 amps. The dome light draws 10 amps. The fuel injectors draw 10 amps. Been doing it for years and I know that it works. The reason for having all of those switches is to leave some on ad turn some off. Not very many people I know turn off their ac controls when they get out of their car. Not many will notice if you reach up and tap yur dome light switch, or tilt your steering wheel before you start your car because that is normal.
Old Nov 13, 2003 | 07:50 PM
  #27
joeymachado's Avatar
Default Re: Quick way to prevent theft (RiceRacist)
hey was up im interested in that flip out monitor and slip stream rims....tell me about both of them maybe send me some picture ?....let me know was up email me prominentstylez@aol.com
Old Nov 13, 2003 | 07:55 PM
  #28
Default Re: Quick way to prevent theft (VTECorona)
let me know was up with that button under the hood please...
Old Nov 13, 2003 | 10:06 PM
  #29
VTECorona's Avatar
Default Re: (4uhataz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4uhataz &raquo;</TD></TR><TR><TD CLASS="quote">And here is another. The A/C controls in my car have a total amp draw of 20. The fuel pump also has an amp draw of 20. Here is another. The hazard lights on my car draw 10 amps. The computer draws 10 amps. The cruise control draws 10 amps. The ignition draws 10 amps. The dome light draws 10 amps. The fuel injectors draw 10 amps. Been doing it for years and I know that it works. The reason for having all of those switches is to leave some on ad turn some off. Not very many people I know turn off their ac controls when they get out of their car. Not many will notice if you reach up and tap yur dome light switch, or tilt your steering wheel before you start your car because that is normal.</TD></TR></TABLE>
Yes but you are losing the original functionality of the button.
Old Nov 14, 2003 | 12:29 AM
  #30
MestizoRacer310's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECorona &raquo;</TD></TR><TR><TD CLASS="quote">
Yes but you are losing the original functionality of the button. </TD></TR></TABLE>
True, but seeing as how my AC don't work....and I might even pull the whole thing out for weight reduction I could see using the AC button as a hidden switch. But I haven't made final decision so I'm not going to do anything like this yet.
Old Nov 14, 2003 | 06:17 AM
  #31
4uhataz's Avatar
No you don't. You find the constant battery wires and splice into them. They put out enough voltage for those components to run off of them unlike your remote wire for your radio. If they only produced a limited amount of voltage you would have to use relays.
Old Nov 14, 2003 | 08:39 AM
  #32
VTECorona's Avatar
So what your saying is that you run the component and the auxiliary item (fuel pump, injectors, starter) on the same 12+ lead?
Old Nov 14, 2003 | 11:14 AM
  #33
4uhataz's Avatar
That's exactly what I'm saying. As long as the rated amperage for that wire and the fuse are not exceeded is perfectly fine. Yes...that's what I'm saying. I know what your response will be and I will answer it like this. Name all of the components that your car uses relays for except to reverse polarity. there lies your answer.
Old Nov 14, 2003 | 03:37 PM
  #34
VTECorona's Avatar
I just dont understand why honda would use a high rated switch for something small like hazard lights. There is no way I would trust my fuel pump running through my hazard light button or anything of that sort.
Old Nov 14, 2003 | 07:44 PM
  #35
djurbang's Avatar
Default Re: Quick way to prevent theft (tub_sephiroth)
simple solution, park next to a better looking car
Old Nov 14, 2003 | 08:47 PM
  #36
audioroach's Avatar
Default Re: Quick way to prevent theft (djurbang)
Simple solution would be a single immobilzer system. Because few people
have learned how to work with relays...Its a shame really because once you
learn the world is your oyster. Hmm I'm off this weekend maybe I'll set up shop
and do immobilizers for $75.00 per car..what do you guys think huh?
Basically there really is no free lunch....you can do this and stop the avg from
hotwiring and driving away with your car to strip it...not a sleaze with a hook.
So if you want help just ask.
Old Nov 14, 2003 | 08:48 PM
  #37
VTECorona's Avatar
Default Re: Quick way to prevent theft (audioroach)
A homemade immobilizer? huh? what?! explain
Old Nov 14, 2003 | 09:46 PM
  #38
audioroach's Avatar
an immobilizer is basically a circuit that keeps the vehilce from being
started by an unathorized user...also know as "kill-switches",starter kill
ignition interupts etc. I like doing those that simulate engine trouble.
( hey why bother when it wonk kick over )
Old Nov 14, 2003 | 10:06 PM
  #39
VTECorona's Avatar
oic... i wanna put a few more in, all i have now is fuel pump
Old Nov 19, 2003 | 07:31 PM
  #40
Eyes Only's Avatar
take your ecu and a wheel
Old Nov 19, 2003 | 07:53 PM
  #41
VTECorona's Avatar
Default Re: Quick way to prevent theft (Night_Ryder)
I wish there was a way to prevent being flat-bedded. There has to be a way.
Old Nov 19, 2003 | 11:26 PM
  #42
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECorona &raquo;</TD></TR><TR><TD CLASS="quote">I wish there was a way to prevent being flat-bedded. There has to be a way.</TD></TR></TABLE>
Rig it with pager activated explosives... I've said it before, And now I shall say it again... I would rather know that my car blew up and took out a couple of jackers than know that someone is going to rape all my hard work... Don't think it's possible? Come steal my car...
Old Nov 20, 2003 | 06:39 AM
  #43
VTECorona's Avatar
Default Re: Quick way to prevent theft (h8tred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h8tred &raquo;</TD></TR><TR><TD CLASS="quote">
Rig it with pager activated explosives... I've said it before, And now I shall say it again... I would rather know that my car blew up and took out a couple of jackers than know that someone is going to rape all my hard work... Don't think it's possible? Come steal my car...</TD></TR></TABLE>
Very true.. and when the insurance company asks about it ill say "uhhh, they must have dropped a cig under the gas tank...or something." When I get my own place and I'm still into honda's I am going to put a pole into the ground and lock up the car with a thick chain. If I don't have a garage that is..
Jhill_9202
36
Nov 5, 2008 03:59 PM
x_outlaw_x
50
Jan 19, 2006 05:57 PM
uscivicmc
Nov 7, 2005 07:26 PM
skeptic
Nov 10, 2004 09:16 PM
sleepyhamsterlx
Nov 26, 2003 06:52 PM
