quick amp question
Old Nov 15, 2003 | 07:49 AM
integra_dude's Avatar
Default quick amp question
i recently bought an amp and i just for fun took it apart to check everything out. Upon opening it up, i noticed a few things seemed to be held in with hot glue. the amp came from ebay, and it came with everything original packaging and everything, so i figured it was fine, but is the hot glue normal?
Old Nov 15, 2003 | 07:59 AM
EBP_SI's Avatar
Default Re: quick amp question (integra_dude)
does the amp work?
Old Nov 15, 2003 | 08:07 AM
Default Re: quick amp question (EBP_SI)
i havent hooked it up, i'm collecting parts for my new system right now, do u think its a really big deal?
Old Nov 15, 2003 | 08:11 AM
EBP_SI's Avatar
it wouldn't suprise me...i have seen some things held in place by glue.
Old Nov 15, 2003 | 08:13 AM
so it shouldnt be anything to worry about?
Old Nov 15, 2003 | 08:24 AM
EBP_SI's Avatar
what exactly is it thats held in place with glue?
Old Nov 15, 2003 | 08:27 AM
i dont even know wut they r called if u look at from above, they look like doghnuts made out of wire if that makes any sense
Old Nov 15, 2003 | 08:51 AM
actually, i just looked at the box cover, and in one angle noticed that there is hotglue on some of the things, so i'm assuming that its fine.
Old Nov 17, 2003 | 09:31 AM
Stew Pidasso's Avatar
Are you sure it's not epoxy?
Old Nov 17, 2003 | 11:55 AM
doublejz's Avatar
Default Re: quick amp question (Stew Pidasso)
thats the way most are held in the amp, i have had many amps with the same as your described
Old Nov 17, 2003 | 12:31 PM
QWKVTEC's Avatar
I have been installing and working on car audio products for 8 years and the "glue" that you saw is completely normal. The wire that you see is a coil for the power supply.
Old Nov 17, 2003 | 03:37 PM
Tw1n Turb0 Z's Avatar
Default Re: quick amp question (QWKVTEC)
QWK is right
Those are the coils you have seen and glue is used because its non-conductive to the board that its resting on, unlike some other "bonding" materials such as solder (conductive) which is used to actually transfer engergy in the form of a connector
Old Nov 17, 2003 | 10:34 PM
NOOTRON20's Avatar
those are power coils..........there should'nt be anything wrong w/ your amp. the factory uses glue just to hold parts in place .
Old Nov 18, 2003 | 09:15 AM
thanx for all ur help guys, u said the words i wanted to see
Frozen E
Audio / Security / Video
Sep 26, 2009 03:10 PM
Ehop
Jan 19, 2008 07:12 AM
CHK4TIX
Jan 11, 2004 08:46 AM
darkvibe
Oct 12, 2003 05:18 PM
civicmark
12
Nov 10, 2002 11:25 PM
