python/dei old alarms owners
Old Sep 24, 2003 | 01:19 AM
MileHigh's Avatar
Default python/dei old alarms owners
anyone knows where i can find this remote replacement of my Pythoon/ DEI alarm system... it has 4 buttons (8 channels - I believe)
this is the only remote i have for my alarm, and if anything happens to it, i cannot disarm my car nor start it (starter kill)... unless i uninstall the wires and starter kill relay (which is a pain in the a)
or do you know any of the newer DEI remote models are compatiable with this let me know please, thanks
Old Sep 24, 2003 | 04:17 AM
HondaDriver4Life's Avatar
Default Re: python/dei old alarms owners (MileHigh)
On the back of the remote there is a FCC ID# - what is it?
Old Sep 24, 2003 | 04:19 AM
audioroach's Avatar
actually you have a 16 channel remote ( dont ask how I know )
You can get a replacement at any DEI dealer....your system is
a code learning type. You just have to bring it in to any dealer,
pay and 30 secs later ( avg time ) you good to go. Just look at the
led color ( red or green,solid or pulsing ) pick a style ( you can
even use a 2 button style ( depending on what features yours
works)) ...its that simple.
laterz
Old Sep 24, 2003 | 04:39 AM
rjr162's Avatar
Default Re: python/dei old alarms owners (audioroach)
it could be the older style where you actually have to scratch the traces off the board.... how old is the unit etc? Reguarless if you know the model # for the remote (Typically has RP/N-XXXX<Letter&gt then you'll be good to go at any dealer
oh, and if you're not sure of the remote # but know the brain # go to http://www.directed.com and you can cross-reference the remote # to the brain #
Old Sep 24, 2003 | 04:50 AM
You can disarm via the valet switch - turn the ignition to ON, press and release the valet switch within 15 seconds.
DEI offered your remote in a couple of different versions. This is why the FCC ID# is important - the last 3 digits will tell you which series you have.....484 or 485. The 485 series has 60-channels, rolling code technology and transmits on 433 MHZ. The 484 series only has 15-channels, non-code hopping and transmits on 302 MHZ.
If you have the 485 series, the replacement remote is the 485M or 485T. If you have the 484 series, the replacement remote is the 484T. Most online retailers sell them for $45 and you can program the remotes in less than 30 seconds.
Old Sep 24, 2003 | 07:56 AM
MileHigh's Avatar
oh alright...
i have the 485 remote...
guess it'll be the 485M remote since the T series are more expensive!!
so i guess i cant just pick up a cheapo DEI remote and program it with my alarm? not competitable..?
thx for the help guys
Old Sep 24, 2003 | 08:34 AM
Default Re: (MileHigh)
The remote has to match the brain in order for it to work.
Old Sep 24, 2003 | 08:41 AM
MileHigh's Avatar
Default Re: (HondaDriver4Life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaDriver4Life &raquo;</TD></TR><TR><TD CLASS="quote">The remote has to match the brain in order for it to work.</TD></TR></TABLE>
that of coz... so i guess i have to get that particular model by DEI then
i was just thinking if all the DEI remotes works the same way, just need to program it to the system... ever go to best buy and stand in front of their TVs.. for example, the SONY remote will work with most of the SONY models...
i know this is different case but just wondering if lets say the 4XX remote will work with a different DEI system with a different XXX number after you program it
Old Sep 24, 2003 | 08:51 AM
That would be a tremendous security risk if DEI made their units in that manner you described. Thieves would have a field day!!
The difference is that not all DEI models transmit on same frequencies. What kind of price ranges are you seeing for remotes? Are you looking at getting a 2-button instead of another 4-button?
There's an online retailer (autoteachs.com) that sells the remote(s) that you need for $45 plus shipping. They're based in FL so shipping should only take a day or two.
Old Sep 24, 2003 | 12:12 PM
MileHigh's Avatar
well, i like my 4-button remote
lets see... lock, unlock, slient, panic, assessory1(lights), assessory2(radio), assessory3... that's all i have programed on it...
so i dont want to settle for a 2-button if i lose my assessories
but $45 seems too much for just a little remote... hmmm, i guess i can search on ebay if not i'll just hope nothing will go wrong with my remote
thx for your help HondaDriver4Life
Old Sep 25, 2003 | 04:13 AM
I agree $45 is too much but unless you know someone that can get it to you at dealer cost, that's the cheapest I've seen for a brand new remote. Hopefully Ebay works out for you. Good luck!
Old Sep 25, 2003 | 05:18 AM
realblag's Avatar
You will also need the date code and the model number off the brain box. That particular remote is programable at the brain. If it was installed correctly, you will have to get to the brain to program the remote because there is a little dip jumper inside that has to be moved to the program position. Then you have to jump through hoops to program it. It would be wise just to let a DEI dealer do it.
Old Sep 26, 2003 | 04:16 AM
Default Re: python/dei old alarms owners (realblag)
I think you're getting your models confused. As long as he's using the proper replacement remote, all he has to do is enter the learning mode through the valet switch. A few button clicks later and the remote is programmed. I have a Python 3000 that uses the same remote. I recently was able to program 2 remotes in under 30 seconds. Letting a DEI dealer do it is a waste of time and money.
Old Sep 26, 2003 | 07:10 AM
itsmike's Avatar
Default Re: python/dei old alarms owners (HondaDriver4Life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaDriver4Life &raquo;</TD></TR><TR><TD CLASS="quote">I recently was able to program 2 remotes in under 30 seconds. Letting a DEI dealer do it is a waste of time and money.</TD></TR></TABLE>
How do you program a new remote to your existing alarm? (dei models)
Old Sep 26, 2003 | 11:54 AM
Default Re: python/dei old alarms owners (bluesolguy)
How old is your alarm and what model is it?
Most DEI alarms learn new remotes this way:
1. Open a door
2. Turn the ignition ON
3. Select the receiver channel by pressing and releasing the valet switch the
appropriate number of times. For example - channel 1 would require one press
and release.
4. Press and hold the valet switch once more. The siren will chirp according to the
channel you have accesses. The LED will blink accordingly as well.
5. While holding the valet switch, press the
desired remote button until you hear a chirp. The channel has now been
program.
To move to the next channel, just press and release the valet switch one time and go to step 4. You should now be at the next channel.
The process is tricky at first but after a few passes, you'll get the hang of it.
Old Sep 26, 2003 | 02:55 PM
realblag's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaDriver4Life &raquo;</TD></TR><TR><TD CLASS="quote">I think you're getting your models confused. As long as he's using the proper replacement remote, all he has to do is enter the learning mode through the valet switch. </TD></TR></TABLE>
On the casing of your Python 3000 brain is a little slide off cover. In side are a pair of jumpers. One of them locks the brain out of program mode so you can't program anything after its installed. If it was installed correctly,after the installer was through, its the last thing he should have done. It keeps people from messing with his final set-up and keeps theives from programing their own remote to your car. I dont think you want a thief jumping in your car and programming HIS own two remotes to your car in 30 seconds. The jumper doesn't have to be set, but its a good idea.
Old Sep 26, 2003 | 07:11 PM
itsmike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaDriver4Life &raquo;</TD></TR><TR><TD CLASS="quote">How old is your alarm and what model is it?
1. Open a door
and release.
program.
The process is tricky at first but after a few passes, you'll get the hang of it.</TD></TR></TABLE>
Are you talking about changing a feature in the alarm? Or is this for adding new remotes to the system.
Old Sep 26, 2003 | 07:15 PM
rjr162's Avatar
it's for adding new remotes. To program features you turn the ignition on and then off. To add remotes, you just turn it on. Also note, most DEI alarms have the auto-learn feature. You'll have to look at the guide on DEI's website to figure out if yours' has it and what programming option # it is. By doing it this way you just have to push button I and the whole remote is programmed in. If you don't do it this way, you typically have to program each channel (button) on the remote into the brain.
Old Sep 27, 2003 | 06:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realblag &raquo;</TD></TR><TR><TD CLASS="quote">
On the casing of your Python 3000 brain is a little slide off cover. In side are a pair of jumpers. One of them locks the brain out of program mode so you can't program anything after its installed. If it was installed correctly,after the installer was through, its the last thing he should have done. It keeps people from messing with his final set-up and keeps theives from programing their own remote to your car. I dont think you want a thief jumping in your car and programming HIS own two remotes to your car in 30 seconds. The jumper doesn't have to be set, but its a good idea. </TD></TR></TABLE>
That WOULD NOT happen with MY installs. First, the thief won't have a key and second, I don't place the valet switch in plain sight. I also use decoys in the most common areas that valet switches are installed. Even if he/she had a key, they would still have to find the switch.
ipleadthe5th
Audio / Security / Video
16
Apr 21, 2017 06:49 PM
tvman
Dec 8, 2008 05:44 PM
AbeFroeman
Jan 30, 2006 10:35 AM
aquarius
Jul 15, 2004 07:53 AM
stock97
Dec 18, 2003 11:12 AM
