Push button to start car.
Old Jan 24, 2005 | 02:53 PM
B18OnTop's Avatar
Default Hold a button to start car.
I have a 99 ls teg with a turbo timer. I want to have a button hidden in my car so when I go to start the car I have to hold the button down to start it. I don’t know much about wiring things. I would think if I spliced into one a the ignition wirers fare back in the dash would be the best idea. I’m no sure on witch wire to splice into. I was hoping you guy could help me on how to go about doing this.
I was thinking of using a button like this.
http://www.radioshack.com/prod...D1556
Thanks
-Aaron
Modified by B18OnTop at 9:14 PM 1/24/2005
Old Jan 25, 2005 | 07:27 AM
fcm's Avatar
fcm
Old Fart
Default Re: Hold a button to start car. (B18OnTop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18OnTop &raquo;</TD></TR><TR><TD CLASS="quote">I have a 99 ls teg with a turbo timer. I want to have a button hidden in my car so when I go to start the car I have to hold the button down to start it. I don’t know much about wiring things. I would think if I spliced into one a the ignition wirers fare back in the dash would be the best idea. I’m no sure on witch wire to splice into. I was hoping you guy could help me on how to go about doing this.
http://www.radioshack.com/prod...D1556 That will work install it on one of the wires going to the clutch safety switch, so even if you step on the clutch, unless you push the switch the starter relay will not work. 94
Modified by B18OnTop at 9:14 PM 1/24/2005</TD></TR></TABLE>
Old Jan 28, 2005 | 11:49 PM
sdinteg's Avatar
Default Re: Hold a button to start car. (fcm)
Just splice a momentary pushbutton switch in series with the start signal from the ignition switch.
What would be the point if the car can just be push started anyway?
Old Jan 29, 2005 | 06:44 AM
fcm's Avatar
fcm
Old Fart
Default Re: Hold a button to start car. (sdinteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sdinteg &raquo;</TD></TR><TR><TD CLASS="quote">Just splice a momentary pushbutton switch in series with the start signal from the ignition switch.
What would be the point if the car can just be push started anyway?</TD></TR></TABLE> Just one more layer, makes it harder, takes longer.
The best security you can have is a layered system, diff., independent things, its all about making it harder, slowing the crook down, making move on to a "softer" target 94
B16EJ
Sep 23, 2015 07:58 PM
yarara0825
Oct 22, 2007 04:31 PM
Josky4ya
Dec 14, 2005 01:01 AM
B18OnTop
Jan 26, 2005 01:03 AM
B18OnTop
Jan 25, 2005 01:58 AM
