Purpose of this DOOR INPUT TRIGGER on a viper security system?
What is the purpose of a "door input trigger wire" (green) on viper alarms? And what wire would I hook it up to on a 92 civic?
cant remember off hand which wire this is in the civic but the purpose is basically what is says...."door trigger" is going to sense when the door has been opened and set off the siren...you need to hook this up
the wire is light green/red in the driver kick panel it will test negative....aka it will go to ground when the door is opened
Ditto the above, green on Viper alarm is neg. (-) door trigger, [Honda/Acura and most other cars] the violet H1/7 on Viper alarms is the pos. (+) door trigger, [Ford and some other makes].
94
94
w1ck3dR
Audio / Security / Video
Feb 17, 2009 07:36 PM
