any help appricated
Old Nov 18, 2008 | 05:13 AM
steveharrmr23's Avatar
Default any help appricated
on my security system there are a few wires i need help with i am working on a 94 dc4.
i have a door + and a door - which one get hooked to which wire in the cars door lock system?
there is also a #3 channel - wire what is it for?
there is also a trigger - wire what is that for?
Old Nov 18, 2008 | 05:34 AM
B18C_EJ8's Avatar
Door triggers have nothing to do with your locks. Door trigger inputs get hooked into door triggers. Lock outputs get hooked to lock wires.
#3 channel is an aux channel, normally used for trunk pop. If your vehicle does not have power trunk release, then you would not use this wire.
A trigger wire? You'll have to be more specific. What does the manual say it does? It's apparently an input for the alarm, but to what it gets connected to is a mystery. It's probably a hoodpin or trunk trigger, but we'll wait until you crack open the manual and tell us a little more...
Old Nov 18, 2008 | 05:36 AM
fcm's Avatar
fcm
Old Fart
Make and model of alarm would help.
The "door + and a door -" are not for the cars door locks, they are for the door trigger, you will use the door -, [the door + is not needed].
The #3 channel is an EXT output, it would be used for something like trunk release or a power window module. also not needed in your car unless you want to add something like a power window module.
the "trigger - wire" can be used for a hood or trunk/hatch trigger.94
Old Nov 18, 2008 | 05:57 AM
it is a avistart 4100 series but i am not using the remote start part of is so i am only using the freedom 500 module for the keyless entry and secruity system also i got it out of a car that was totaled in a junk yard
Old Nov 18, 2008 | 05:59 AM
what is a door trigger do you mean that button inside the car
Old Nov 18, 2008 | 04:43 PM
fcm's Avatar
fcm
Old Fart
The "door triggers" are the pin switches in the door jamb that turn on the dome light. 94
Old Nov 18, 2008 | 06:24 PM
oh hell i feel stupid now does anyone know how to get ahold of the company that makes the freedom 500 keyless entry security system
Old Nov 19, 2008 | 06:05 AM
fcm's Avatar
fcm
Old Fart
http://www.directeddealers.com/manua...1002_07-05.pdf 94
Old Nov 19, 2008 | 06:35 AM
thank you so much fcm i tried callin avital i sat on hold for two hours in which time they closed i was pissed
Old Nov 19, 2008 | 01:41 PM
got it all figured out thx to all of yall that provided me with the information to make it possible it is so much fun for like five minutes i would arm it just to set it off haha i know not a good thing but could not help it
w1ck3dR
Audio / Security / Video
Feb 17, 2009 07:36 PM
carcraftlude
10
Oct 3, 2008 07:56 AM
saveacivic
21
Jan 24, 2007 07:18 PM
Odessa
19
Aug 3, 2004 06:37 PM
Cycoco
Feb 15, 2004 08:12 PM
