Problems with the door trigger wire
Old Apr 17, 2005 | 05:22 PM
vtec94civic's Avatar
Default Problems with the door trigger wire
alright my brother has some cheap performance technique alram that he bought just to beef up on security since he already has a detachable steering wheel and the autoloc. he was installing the alram and when it came time to check if everything works there is a problem with the door trigger wire.
it seems that the alarm can't read the - pulse from the door. i just keeps on showing that the door is open. he also tried to run a wire from the dooor sensor itself and hook it up to the alram and the same thing happens. the ground is good and it works perfectly fine. a funny thing happened when he tested the gound with a test light. when he hooked the test light o a 12 volt source and then poked the wire to test the ground the alarm recognized the door trigger and began working fine. when he took the probe out it started to act up again. he then tried to hook up a 12 volt source to the wire to simulate the test light but then the wires started to burn up.
we never seen this happen before. my brother has installed a few alrams in civic's before and did two for me(aladdin 2000 and a compustar) and he never ecountered this problem with the trigger wire. he has everything hooked up properly we think its just the shitty alarm.
if anyone has anything just leave some feedback
foot notes: door sensor has proper ground and lt green/red wire has good ground when door sensor is triggered. alarm is not responding to door trigger and always thinks the door is open. put positve power from test light to wire and then began to function properly but if hooked up to a direct 12 volt fused source wire will burn.
Old Apr 17, 2005 | 08:34 PM
audioroach's Avatar
Default Re: Problems with the door trigger wire (vtec94civic)
Hmm did you read the manual? In some cases the alarm has to be programmed
for door trigger polarity. The way you guys are testing things scares me. Go back through and triple check your work.
Old Apr 18, 2005 | 09:03 AM
found the problem. it was pretty stupid there was no dome light bulb. i hooked up everything and now it works fine. oh and btw the alram already had two wire for the door trigger polarity meaning that it had a + and - wire.
kjrayo18
Jul 21, 2014 06:47 AM
Dub C
Audio / Security / Video
Mar 17, 2006 10:33 AM
low_crx87
Oct 8, 2005 12:58 PM
civicmark
Jan 2, 2003 11:31 AM
DocYahoo
15
Jul 20, 2002 04:29 PM
