Problem with keyless entry and radio
Old Jun 11, 2005 | 10:26 AM
utahchunk's Avatar
Default Problem with keyless entry and radio
ok so i have a 96ex civic and i have a aftermarket HU installed. i used the special harness that is needed to hook it up also. well this is my problem one morning i woke up and my battery was nearly dead. (enough that my car would not even start) I charged it back up and all. the weird thing is that everytime that i press the key fab the siren always beeps. (not normal) i cant figure it out. i checked all the wires and could find nothing. the only thing i could find is that the fuse box under the hood has a possible short comming from the radio and interior light fuse. which goes back to the keyless entry. Please help me out ...
Old Jun 11, 2005 | 11:12 AM
fcm's Avatar
fcm
Old Fart
Default Re: Problem with keyless entry and radio (utahchunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by utahchunk &raquo;</TD></TR><TR><TD CLASS="quote">ok so i have a 96ex civic and i have a aftermarket HU installed. i used the special harness that is needed to hook it up also. well this is my problem one morning i woke up and my battery was nearly dead. (enough that my car would not even start) I charged it back up and all. the weird thing is that everytime that i press the key fab the siren always beeps. (not normal) i cant figure it out. i checked all the wires and could find nothing. the only thing i could find is that the fuse box under the hood has a possible short comming from the radio and interior light fuse. which goes back to the keyless entry. Please help me out ...</TD></TR></TABLE>If you ran into this problem after you installed the aftermarket HU I would pull the HU, reinstall the OEM HU properly, and see what happens, if problem is gone, then it has to have something to do with the aftermarket HU, the adpt. harness, or how it was wired. 94
Old Jun 14, 2005 | 09:11 AM
utahchunk's Avatar
Default Re: Problem with keyless entry and radio (fcm)
ok so i have already put the factory HU back in as if it was stock. I still have the same problem. I cant figure this crap out at all.
Old Jun 14, 2005 | 11:12 AM
rtpassini's Avatar
did you try replacing the fuse?
Old Jun 16, 2005 | 01:13 PM
utahchunk's Avatar
yep. still wont work right.
Old Jun 18, 2005 | 05:26 PM
dc24me's Avatar
if you are talking about factory honda keyless entry, it might have defaulted back to the original settings.
my sisters 01 sentra se had keyless entry from the factory. initially when she pressed the button, the horn honked. there was a simple program in the manual (actually it may have even been on the transmitter itself) that allowed it to be silent all the time. hopwfully yours is similar.
did you look in the owners manual of the car?
Old Jun 19, 2005 | 01:27 PM
rtpassini's Avatar
thats kinda like what happened with my brother if you press the unlock and lock buttons at the same time. it goes into silent mode. he has a viper alarm
Old Jun 20, 2005 | 07:11 PM
obie2102's Avatar
In any 96-98 civic w/factory keyless you have to keep the factory radio plugged in behind the dash using a t-harness available at a local audio shop. The keyless is partially built into the factory radio and must remained powered up. Make sure the green plug is also plugged back into the factory radio when re-installing or you could still have a problem. If it is plugged in, you will most likely have to have your keyless system re-programmed.
Old Jun 21, 2005 | 01:27 PM
fcm's Avatar
fcm
Old Fart
Default Re: (obie2102)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obie2102 &raquo;</TD></TR><TR><TD CLASS="quote">In any 96-98 civic w/factory keyless you have to keep the factory radio plugged in behind the dash using a t-harness available at a local audio shop. The keyless is partially built into the factory radio and must remained powered up. Make sure the green plug is also plugged back into the factory radio when re-installing or you could still have a problem. If it is plugged in, you will most likely have to have your keyless system re-programmed.</TD></TR></TABLE> You only have to leave the oem radio in if you are not installing an alarm or remote start or any RF unit, [keyless entry] as it is the RF section that is in the oem radio, and I agree it's a programing issue although I have never heard a Honda Civic with an oem K/E"chirp" 94
Fantastic420
Sep 25, 2009 08:08 PM
patrickstar
Audio / Security / Video
Aug 23, 2009 08:51 AM
91EF_Si
Dec 23, 2007 08:44 AM
sireg6
Jul 29, 2006 09:40 PM
RSVTECDC4
Mar 15, 2004 10:08 PM
