power wire arced on ground to amp, helppp
Old Jun 29, 2010 | 02:20 PM
2toneDA's Avatar
Default power wire arced on ground to amp, helppp
so i have a 2000 base model prelude, i was taking out the back seats to make room for a seat belt harness bar, i had to relocate a sub amplifier under the drivers seat, and when doing so the positive got loose and arced with the ground to the amp, (i know i should have disconnected the anl fuse but i forgot) also i don't know the relevance but the shop that connected the system got power from the fuse box under the hood, it was connected to 100A battery connection, my problem now is that when i turn my car on the gauge cluster runs fine but when i turn the a/c on the cluster quits working, the interior lights dim and the radio cuts on and off
Old Jul 5, 2010 | 06:18 PM
fcm's Avatar
fcm
Old Fart
Default Re: power wire arced on ground to amp, helppp
Check your grounds, generally when differant circuits effect one and other it is a grounding issue. 94
Old Jul 15, 2010 | 06:00 PM
2toneDA's Avatar
thanks bro it turned out to be the ground to the battery,
2toneDA
Jul 15, 2010 05:52 PM
The G2 Racer
Audio / Security / Video
Sep 23, 2008 07:28 PM
Skeletor
Sep 6, 2007 09:50 AM
shawn69
Jan 21, 2007 11:47 AM
2K GSR
Jan 15, 2004 08:46 PM
