power question?? pls help
Old Jan 22, 2004 | 10:25 AM
PearlWhiteAccord's Avatar
Default power question?? pls help
i have a device that runs on 10.5v DC at 1.2 amp...
can i put a wire connecting to the car battery to the device to power it up??
will it blow???
Old Jan 22, 2004 | 06:43 PM
B18C_EJ8's Avatar
Most devices have an over/under current tolerance built right in, but usually that variance is only a couple of volts either way... If your charging system is good, and puts out the 13.8-14v it should, then you may want to buy a universal adapter with a step-down transformer, that'll give you 10.5 or 11 volts...
95accordman123
Audio / Security / Video
Jun 27, 2008 09:18 PM
fryman
Jun 11, 2008 05:41 AM
xkrntamax
Jan 4, 2007 05:27 PM
hatchinprogress
Mar 8, 2006 05:18 PM
1tyme
Dec 18, 2002 04:33 PM
