power question
Old Dec 18, 2002 | 01:17 PM
1tyme's Avatar
Default power question
ok i'm installing a dvd player, monitor, and fm modulater. my question is can i run those 3 power wires off the same wire that my deck is running off? or will it suck all the juice and make my deck weaker? i'm also running my boost and a/f gauge power off the deck power wire. so that would be 6 different things (including the deck) that will be powered by that 12v ingnition wire that is supposed to be used by the deck. i'm not sure on how circuit power goes series or parallel or watevers, but my question is will this setup work fine or should i find a different power source, and if so where?
Old Dec 18, 2002 | 01:28 PM
Desslok's Avatar
Default Re: power question (1tyme)
I would run a new wire from the battery and fuse it according to the amp ratings of the individual components added together.
Old Dec 18, 2002 | 01:30 PM
1tyme's Avatar
Default Re: power question (sp)
but if i do that won't those accesories be on all time?
Old Dec 18, 2002 | 02:17 PM
nsxxtreme's Avatar
If you want to power multiple items from the accessory wire and are worried about current draw use a relay.
Old Dec 18, 2002 | 02:24 PM
Desslok's Avatar
Oh yeah, go to the accessory wire at the steering column, the big fat on, that way it can handle the amperage/voltage.
Old Dec 18, 2002 | 03:04 PM
1tyme's Avatar
Default Re: power question (nsxxtreme)
should i be worried about current draw with these accessories? cause i'd like to run it off of the stereo accessory wire cause of ease. but i dunno. wat is a relay and how do you run one?
Old Dec 18, 2002 | 04:33 PM
Desslok's Avatar
You could ghetto it and bump up the fuse for the radio at the kick panel. But then you run the risk of damaging equipment or possibly catching that thin wire on fire.
Mr.Death
Jul 7, 2007 11:51 AM
Tonyl507
Audio / Security / Video
10
Apr 23, 2007 03:50 PM
jadugartir
May 22, 2005 01:26 PM
itsJDMyo
Nov 24, 2003 01:02 PM
crxaddikt
16
Oct 23, 2003 05:43 AM
