power off sub thump
Old Aug 30, 2007 | 09:35 AM
suspendedHatch's Avatar
Default power off sub thump
93 Civic, alpine deck, infinity basslink II (sub/amp combo)
My basslink II is a little over a year old and has always worked fine and sounded great. Now a few days ago it started this stupid ****. When I pull the key out, it makes a loud thump. It still does it with the RCAs unplugged. I disconnected the remote wire to the deck and jumpered the amp's remote turn on to the amps constant. When I remove power from the remote turn on, it thumps.
The amp is connected directly to the trunk mounted battery, power and ground. The battery is grounded to each of the frame rails with 4 gauge wire. Power is ran to the starter with 4 gauge wire.
I guess this thing has taken a **** after just over a year of light usage? Anyone ever dealt with Infinity's warranty dept?
Old Aug 30, 2007 | 10:04 AM
B18C_EJ8's Avatar
It's like back in the day when you weren't cool unless you had some killer turn-on thump... It let everyone know that you had a bumpin' system...
Then, they came out with this "soft turn on" crap... No one knew what you had anymore, so alot of guys lost out on the poon...
Consider yourself lucky, guy... It's like a gift from God... In reverse.... LOL
Old Aug 30, 2007 | 11:31 AM
Default Re: (B18C_EJ8)
Well I'm practically married, so poontang is not an issue.
I'll look into it though.
Old Aug 30, 2007 | 11:41 AM
fcm's Avatar
fcm
Old Fart
Default Re: (suspendedHatch)
Look for a bad cap in amps power supply, possibly a cold solder connection in the ground circuit of the PC board.
I have never had a problem with Infinity's warranty dept., but then again I am in CANADA EH. 94
Old Aug 30, 2007 | 05:46 PM
JSPECSIR's Avatar
Default Re: (fcm)
i thought you worked at best buy? just switch it with a new one and devo that bitch. i just did it the other day with my 791 remote. my wifey dropped it and spattered the screen. ****, i went straight the hell to work, swapped it and devo'd it. hell we store use 12 packs of dynex AAA's for all the installers 791 remotes. come on man, perks of the position.
Old Aug 30, 2007 | 05:58 PM
B18C_EJ8's Avatar
Default Re: (JSPECSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR &raquo;</TD></TR><TR><TD CLASS="quote">i thought you worked at best buy? just switch it with a new one and devo that bitch. i just did it the other day with my 791 remote. </TD></TR></TABLE>
One of the few (very few) reasons I really really miss working there...
Devo & free/almost free Dynex batteries FTW!!
Old Aug 30, 2007 | 09:29 PM
We carry the Basslink I and not the II.
I'll look for my warranty papers (probably expired) and then I'll try what fcm said. Sounds do-able, but in the past any time I looked at a circuit board trying to find something obvious, I felt like a caveman.
Aw, ****. I said something racist again. Sorry! I'm sorry!
I am a nerd.
Old Aug 31, 2007 | 01:10 AM
jesseman's Avatar
Unless you posted this before you talked to me. Again...Like I told you before, the amp has shorted an inductor. When an inductor in a filter network shorts, it supplies a pure ground to the VCC path. It may not be much current, but it senses that ground across a capacitor in the network and then it discharges. Behold the thump. From what you told me earlier that is the only explanation that I can come up with. Hence the bad crossover we experienced today. Pop the speakers and you only heard a buzzing sound is an open inductor, charging the capacitor and the inductor has no path to ground. Replace that Bitch.
BTW I love that Basslink II, it sounds amazing in an extended cab pickup or a hatchback. Nice and tight bass.
Old Aug 31, 2007 | 07:46 AM
Default Re: (jesseman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jesseman &raquo;</TD></TR><TR><TD CLASS="quote">Unless you posted this before you talked to me. Again...Like I told you before, the amp has shorted an inductor. </TD></TR></TABLE>
Yes, I did. Farmer, look at the timestamp. But are you ******* drunk? You didn't say anything about an inductor. Did I hit my head or something? I don't remember us talking about it to any great length.
That Jetta probably just has the woofer disconnected or grounded.
Old Sep 6, 2007 | 11:05 AM
Default Re: power off sub thump (suspendedHatch)
Okay, what am I looking for?
Old Sep 6, 2007 | 11:21 AM
jesseman's Avatar
Anywhere there is a power or filter network, bring it to work. Look for wire coiled up small or large usually in the shunt path of a filter network.
PnoyJeff
Audio / Security / Video
11
Feb 18, 2006 11:32 AM
allmotorEG-SI
18
Apr 9, 2005 10:26 AM
kevinoneill
21
Feb 29, 2004 09:58 PM
mattduskater
May 12, 2003 04:49 PM
haloseven
Mar 12, 2002 07:21 PM
