Optima problems
Old Sep 24, 2003 | 03:35 PM
Trooper's Avatar
Default Optima problems
Ok , I got a optima yellow top and it doesn't even hold a charge for a day. wtf?
No i have taken it out of the car and charged it over the weekend and it worked fine for 2 days then died. My old Honda battery didn't have this problem. I am pretty dam sure that i don't have any current draw with the key off. Do you guys think that maby my alternator went out with the new "load" of a new battery? thanks for your help
Old Sep 25, 2003 | 12:34 AM
Demented's Avatar
Yellow top is a deep cycle battery and shouldnt be used as a primary battery. Deep cycles do last long.. u might have a draw of alternator is bad
Old Sep 25, 2003 | 05:26 AM
realblag's Avatar
Default Re: (Demented)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demented &raquo;</TD></TR><TR><TD CLASS="quote">Yellow top is a deep cycle battery and shouldnt be used as a primary battery. </TD></TR></TABLE> Absolutely true. The yellow top is designed to be charged, then completely discharged. Running it as a main will kill it since unless you forget and leave your lights on, it will never get completely discharged and It will be getting charged when your driving around (over charge).I dont think 2 days would be enough to kill it though. Check to see if the car is charging. With the car running and the headlights on, a volt meter on the battery should read around 14volts.
trdcelica00
Jan 17, 2007 04:32 AM
dog the bounty hunter
Feb 5, 2006 11:50 AM
Boxcar
Audio / Security / Video
16
May 1, 2005 12:54 AM
thehatchninja
Apr 1, 2004 03:10 PM
deeksmooth
Jan 10, 2004 10:43 AM
