oil pressure sensor question
Old Apr 13, 2006 | 06:18 PM
Michler's Avatar
Default oil pressure sensor question
does anyone know how to hook the power wire [to the LED] up so it only turns on when I turn my headlights on? I want to do this without going straight to the fuse box.
Old Apr 13, 2006 | 06:23 PM
B18C_EJ8's Avatar
Um, what? Are you talking about only having the gauge operate when your headlights are on? Or are you asking how to get the gauge's illumination to turn on when your headlights are on?
Old Apr 13, 2006 | 06:26 PM
Michler's Avatar
Default Re: (B18C_EJ8)
No... how to get the gauge's illumination to turn on when my headlights are on.
Old Apr 13, 2006 | 07:18 PM
B18C_EJ8's Avatar
Lots of ways to do it, but probably easiest is to tap the parking light wire at the switch or dimmer. Or, you could pull the cluster and tap the illumination circuit there. Or, you could grab the signal in the radio harness...
What vehicle are we working on?
Old Apr 13, 2006 | 08:30 PM
romoracing's Avatar
Default Re: (Michler)
just get a add-a-circuit from pepboys (5 to 10 bucks) and put the add a circuit in the headlight fuse location(with 2 fuses in the add a circuit) then run the wire up to the gauges. Easier done then said.
Old Apr 14, 2006 | 12:15 PM
fcm's Avatar
fcm
Old Fart
Default Re: (romoracing)
Actually plugging the gauge's illumination wire into the park light free pin, [assuming its a Honda/Acura] would be easier, use the free pins, thats what they are there for. 94
Old Apr 14, 2006 | 03:39 PM
Michler's Avatar
Default Re: (fcm)
its a 2000 Civic Si... I'll try the free pins... thanks
curtie94
Mar 15, 2011 09:35 PM
thecruzs2007@yahoo.com
Sep 12, 2009 11:02 PM
ssv05civic
Honda Civic (2001 - 2005)
Feb 4, 2007 07:37 AM
IntegraTypeRyan
Dec 1, 2005 05:58 PM
yellow blur
May 24, 2002 07:33 PM
