need some help from you all :)
Old Jan 13, 2008 | 08:44 AM
LifeMage's Avatar
Default need some help from you all :)
hey anyone know what type of security box this is i got the 96 integra about 6 months ago and just now found it while i am working on the turbo timer, need to find out what type of box this is so i can try to set up a relay...
Old Jan 13, 2008 | 09:32 AM
fcm's Avatar
fcm
Old Fart
Default Re: need some help from you all :) (LifeMage)
Looks like a basic immobilizer, with the "kill" relay built in, [white 2pin plug. black leads].
The "kill" relay/immobilizers leads will be connected to the cars ign. or starter lead, most likely. 94
Old Jan 13, 2008 | 10:05 AM
LifeMage's Avatar
Default Re: need some help from you all :) (fcm)
thanks what wires should i look for when making a relay for a turbo timer and that kill/imobilizer?
Old Jan 13, 2008 | 12:19 PM
fcm's Avatar
fcm
Old Fart
Follow the 2 black leads to where they are connected to the cars wiring, an immobilizer is normally connected to the ign. lead or starter lead, in your case it will be the black/yellow, [ign.] or black/white, [starter], however, the leads can be connected to any number of leads to keep the car from starting.
Let me ask you this, do you have the remote for it, does it work?
If so, what does it disable, will the engine turn over but not start, [ign. disable] or will engine not turn over, "crank", [starter kill]? 94
Old Jan 13, 2008 | 03:55 PM
LifeMage's Avatar
""Let me ask you this, do you have the remote for it, does it work?
If so, what does it disable, will the engine turn over but not start, [ign. disable] or will engine not turn over, "crank", [starter kill]? 94 ""
no i dont have the remote, and if i undo it than it will not turn over or anything, want to wire up a turbo time through it and possible make it into my alarm system if at all possible.
Old Jan 14, 2008 | 06:28 AM
fcm's Avatar
fcm
Old Fart
Default Re: (LifeMage)
Turning it into an alarm system is not possible, if you do not have a remote for it, remove it, if unplugging it prevents the engine from turning over, it is connected to the cars starter lead, use a piece of wire to jump the two pins in the two pin plug, [car side], if car starts follow the black leads to where they are connected to the cars wiring, remove them and reconnect the cars wires to each other, then install your turbo timer, or better yet get an alarm/remote start with turbo timer built in. 94
Old Jan 14, 2008 | 12:49 PM
alex801to410's Avatar
Default Re: (fcm)
Cut the black wires before the plug and solder them back together. All that is is a basic alarm with a starter kill that someone got at autozone or pep boys. If you want a real alarm go with one from DEI.
Old Jan 14, 2008 | 01:56 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: (alex801to410)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alex801to410 &raquo;</TD></TR><TR><TD CLASS="quote">Cut the black wires before the plug and solder them back together. All that is is a basic alarm with a starter kill that someone got at autozone or pep boys. If you want a real alarm go with one from DEI.</TD></TR></TABLE>a real alarm from DEI....you're joking right? I have dealt with DEI alarms for numerous years now and they are not the most reliable alarm available. And yes, they were "professionally" installed by so-called certified installers.
Old Jan 14, 2008 | 03:24 PM
fcm's Avatar
fcm
Old Fart
Default Re: (NVturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo &raquo;</TD></TR><TR><TD CLASS="quote">a real alarm from DEI....you're joking right? I have dealt with DEI alarms for numerous years now and they are not the most reliable alarm available. And yes, they were "professionally" installed by so-called certified installers. </TD></TR></TABLE> Then the problem was the installers, DEI makes very dependable systems, I have run into very few problems with any of their lines, considering how many of them I have installed.
It is not an alarm, it is an immobilizer, there are not near enough leads on it for it to be an alarm.
Even though cutting the plug off the black leads and connecting them together will work, it is not the correct way to do it. 94
ganjasnack
Dec 23, 2024 12:17 PM
Mrnieves98
Audio / Security / Video
Jul 10, 2016 01:04 PM
tr666
Sep 11, 2012 06:43 PM
fil2000ad
Oct 15, 2007 05:23 PM
