need help!!! reception of factory radio is horrible
my fm and am reception is horrible. i didn't really care about it until i got xm. now, when i want to listen to xm, i have to suffer with lots of static. what could be wrong? TIA
Re: need help!!! reception of factory radio is horrible (GreenGSR)
Been there myself. Check your antenna! It is almost 5' when fully extended. Should be 2 pieces. I found this out right here the other day when I was trying to get the Eagles (have XM for regular stuff) and couldn't. Found I had only 1/2 of the antenna out. Tugged the rest of it out and it works great!
Re: need help!!! reception of factory radio is horrible (Intercooler)
yeah, i replaced the factory antenna with one of those rubber Autozone jobs that is supposedly amplified. I originally replaced the factory one because it wasn't working well. the rubber one actually works better but i know i should have a better reception than what i've got. Is it possible for the antenna lead to have somehow been disconnected at the head unit? And also, I've got a six disc that runs through the head and it sounds great. Could i hard wire the xm into the CD lead? thanks again
1 Post
Yes, the antenna lead can become disconnected. Double check it's plugged in properly to the back of the head unit. It is a larger (about 1/8" wide) metal, male connector.
Dan
Dan
dlprince
06-01-2008 08:08 PM
