Need help with RCA converters
Old Jul 12, 2001 | 09:17 PM
HuGEN's Avatar
Default Need help with RCA converters
Hey guys I need some help I'm using my stock deck and I wanted to use an amp. I got this converter that give my head unit RCA output. My question is which wires do I connect to the head unit would they be the speaker wires? Please help very confuse and instructions suck. Thanks
Old Jul 13, 2001 | 08:04 PM
GSRedline's Avatar
New User
Default Re: Need help with RCA converters (LudeRacer)
yes you use the speaker wires coming out of your stock deck.
Old Jul 14, 2001 | 01:26 PM
saucycivic's Avatar
New User
Default Re: Need help with RCA converters (GSRedline)
are you using the amp for the mids and highs or are you adding some subs? if your adding subs, only use the rear speaker wires, and wire the rear speakers, if you have any, in parallel to the front speakers. This way you will have your bass isolated and your mids/highs will be on the front channel while the bass will be on the rear. the only thing is that you wont be able to fade the mids/highs front to rear.
Old Jul 14, 2001 | 02:51 PM
Stephen's Avatar
Default Re: Need help with RCA converters (saucycivic)
Also, don't wire one set of front or rear channels to the amp AND the speakers. Do what saucycivic says and wire all 4 speakers to the front outputs if you are NOT adding a 4-channel amp and are adding just a sub.
If you plan on doing mids/highs with an amp get a 4-channel amp.
Cherry Blossom
Audio / Security / Video
Feb 7, 2005 02:42 PM
BEN52
May 17, 2004 07:47 AM
AndyD
Jul 23, 2003 05:37 PM
all420
May 30, 2003 04:30 PM
Accord15
10
Nov 30, 2001 09:44 PM
