Need help on installing Bazooka tube.......
OK guys, I am stupid when it comes to car audio. I have 2 6x9s, 1 Blaukpunk 2 channel amp, and 1 bazooka 8inch bass tube. I want to get them installed this weekend. What do I need? I am going to replace my rear speakers with the 6x9s. I know they don't fit in the factory location, so I am going to mount them on the trunk board. I want to connect the amp to the tube. I was once told that the factory head unit on my Integra doesn't have RCA jacks, and there for need to buy a high-low level input switch or whatever......what is it that I need? Can anyone help me?!?!?!?!?!?
You will need a speaker level to rca adapter, these are available at Radio shack, Wal-Mart, any car audio retailer( they will probably have nicer brands,...of better quality ).
You will also need an amplifier instalation kit....or peice on together. This will have power cable to run from the battery to the amp., a peice of wire to use for grounding the amp to the frame, a remote turn on lead wire to connect to the head unit or fuse box, a set of RCA cables, and all the assorted connectors you will need.
The impedance of the line-to-RCA convertor is going to increase the overall impedance on your rear speaker system (rear speakers + amp). A side effect may be that the rear speakers may not be as clear as you'd like.
