NEED HELP!!
Old Jul 4, 2003 | 08:33 AM
Turbo Powa's Avatar
Default NEED HELP!!
I have the Prestige APS-996 alarm. I attempted to hook everything up but this crap is so hard to do. I just attepted to connect the main power harness and I dont understand. Last thing I want to do is go to a shop to install it. I just need the siren to work. I'm not worried about hooking it up to the lights yet. Anyone have the same alarm that they installed by themselves? I need as much help as possible. I removed the previous alarm which wasnt even working when I got the car. TIA!
Old Jul 4, 2003 | 09:01 AM
nOOber's Avatar
Default Re: NEED HELP!! (Panda EK)
what connections are you having trouble with ?
Old Jul 4, 2003 | 09:05 AM
Turbo Powa's Avatar
just the main harness. Its 6 wires.
http://www.audiovox.com/webapp...Id=-1
Old Jul 4, 2003 | 10:22 AM
nOOber's Avatar
ok, I'll assume this is going in your 90 crx
+12 Volts: White/black @ Ignition Harness +
Ignition: Black/yellow @ Ignition Harness +
Accessory: Yellow @ Ignition Harness +
Starter: Black/white @ Ignition Harness +
that should help.
Old Jul 4, 2003 | 11:29 AM
Turbo Powa's Avatar
Default Re: NEED HELP!! (nOOber)
so what about the 2 accessory wires?
Old Jul 4, 2003 | 11:33 AM
Turbo Powa's Avatar
oh and I forgot to ask, do i need to use the relay that it came with or is that for the auto tranny remote start?
Old Jul 4, 2003 | 02:45 PM
Turbo Powa's Avatar
bump... i need to save some money here
Old Jul 5, 2003 | 06:23 AM
Turbo Powa's Avatar
anyone?
Old Jul 5, 2003 | 07:46 AM
pickup1's Avatar
what are the colors?are they aux.outputs?you should have a wire for the shock sensor,door trigger...and more.do you have the wiring diagram?list what color wires and what they go to..example...blue or green is door trigger...somthing like that...alarms arent really that hard.just need to have the installation manual.
Old Jul 5, 2003 | 10:04 AM
Turbo Powa's Avatar
Default Re: (pickup1)
I do have the manual but they make it seem so complicated.
njandrewg
Audio / Security / Video
Mar 9, 2005 12:22 PM
im_the_teacher
Jun 4, 2003 05:10 AM
x00gsr
17
Mar 14, 2003 07:23 AM
asianspeed
12
Jan 10, 2003 06:02 PM
