Kill Switch Idea
Old Jun 27, 2003 | 02:34 PM
Henry HA's Avatar
HAnda-Tech Member
Default Kill Switch Idea
I was bored and i started thinking about Kill Switches and how sometimes theifs some times follow the line until they find the switch, well heres an idea. If you have like 6 simultaneous switches and have a few of them switched and a few unswitched and your the only one who knows the "combinatinon" The theif is gonna get confused and leave!
Henry HA's Avatar
HAnda-Tech Member
Default Re: Kill Switch Idea (B18C_DC2)
this is possibly the dumbest post ive ever made. I am feeling stupid
Modified by B18C_DC2 at 4:40 AM 7/2/2003
Old Jun 27, 2003 | 02:55 PM
nsxxtreme's Avatar
About to have a rum and coke myself
This is an old security idea. It does work but all the person has to do is find the in and out of your lock connect them together then there gone. A more secure way is with relays (or transistors) and using evreyday electrical devices inside your car as the combination.
Old Jun 27, 2003 | 10:18 PM
Henry HA's Avatar
HAnda-Tech Member
Default Re: Kill Switch Idea (nsxxtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">About to have a rum and coke myself
This is an old security idea. It does work but all the person has to do is find the in and out of your lock connect them together then there gone. A more secure way is with relays (or transistors) and using evreyday electrical devices inside your car as the combination.</TD></TR></TABLE>
wut is a transistor
Old Jun 28, 2003 | 08:32 AM
JOMO
Guest
Posts: n/a
how the HELL did you post 2 posts at EXACTLY THE SAME TIME?!?!
no matter how drunk/high ive been ive never been able to do it!
the kill switch is a good thought, but think about this, you need at least 1 kill switch that a thief wouldnt think of, like the ECO switch, or even the window lock, or fog light switch, if you wire kills into these a thief is gonna have a head ache
ps:make it so you have one switch you must HOLD DOWN with a spring in it for yoy to start the car, in other words after flipping all your 6 switches, you need to hold onto a press button for the car to start, that is tricky to understand
i have one in the rear windscreen washer, which you just push, doesnt stay on
peace
Old Jul 1, 2003 | 07:33 PM
IgotV-tec!'s Avatar
Default Re: (JOMO)
Sorry guys this might b a dumnb ? but how exactly does the switch work? i know it kills the engine but what is it just wires hooked up to something on the engine? and do you always have to hold it down to turn the engine on?
Old Jul 2, 2003 | 03:39 AM
Henry HA's Avatar
HAnda-Tech Member
Default Re: (LEGENDthatTHUMPS)
Theres a few ways to do it, If your can keep the engine from getting fuel or spark its probably not going to start. A very common way is to the Fuel Pump
Old Jul 2, 2003 | 01:07 PM
IgotV-tec!'s Avatar
Default Re: (B18C_DC2)
well are all the switches the ones u have to hold down and turn on the car at the same time? if not then how can i get it so i have to hold it down?
Old Jul 3, 2003 | 08:24 AM
JOMO_
Guest
Posts: n/a
https://honda-tech.com/zerothread?id=548888
read that topic i started on it
Modified by JOMO_BANNED at 8:25 PM 7/3/2003
Old Jul 4, 2003 | 11:40 PM
Henry HA's Avatar
HAnda-Tech Member
Default Re: (JOMO_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOMO_ &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=548888
Modified by JOMO_BANNED at 8:25 PM 7/3/2003</TD></TR></TABLE>
thanks, wut ever happen to jomo? wud he do?
Old Jul 5, 2003 | 05:51 AM
rjr162's Avatar
that or just wrap your wiring with TONS of electrical tape. Make it look as factory as possible, but as time goes on that stuff turns super tacky and leaves black resido all over the wires and what not... it's a pain to work with.
Or you can also do what I've thought about. do your wiring, wrap it in electrical tape, then get a peice of copper sheet metal, cut it and wrap it around your wiring area. Solder the two ends together (you might need a 2nd small peice of the sheet metal to solder to either side) and then tape that all up to look factory. This way there's an extra layer of un-expected crap you'd have to get past, and solder holds really well on copper. Granted they could try to snip the metal, but if you get it tight against your wires even this would be hard.
If nothing else, the theif might atleast get all cut up.
Old Jul 5, 2003 | 05:59 AM
basshead's Avatar
Default Re: (rjr162)
DO NOT FORGET the razor blades with pepper stuck cleverly under the dash betwen the wires the thieves would be messin wid! now thats fun
ive been banned again but im still here
Old Jul 5, 2003 | 11:49 AM
Henry HA's Avatar
HAnda-Tech Member
Default Re: (newbster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newbster &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT FORGET the razor blades with pepper stuck cleverly under the dash betwen the wires the thieves would be messin wid! now thats fun
ive been banned again but im still here </TD></TR></TABLE>
hahaha nice
how ya been jomo?
Bludger
Sep 26, 2010 07:57 AM
Eyal 951
27
Sep 10, 2005 02:49 PM
Iomega01
Audio / Security / Video
Sep 4, 2005 07:04 AM
Dc2 Powered
Oct 6, 2004 07:01 AM
