my first system, need help
Old Nov 18, 2009 | 08:34 PM
michael-crxsi's Avatar
Default my first system, need help
i have a 91 crx si that i want to get more bass out of. i have to clue about all this sound stuff. im not looking to be crazy loud or make my car shake bad, i just want a good bass sound. some friends have told me two 10's would sound good nut i have no clue. i also need to know what amps to run with it so it all sounds good. im not looking at spending much money. the sound is not my main concern, the engine and body is. so if some one could tell me everything i need and where to get it, FOR CHEEP. id like to stick with Best Buy and Wall-mart if i can. thanks for the help. please dont give me a set up that takes my whole trunk space. i need some room in my trunk
Old Nov 18, 2009 | 08:35 PM
Default Re: my first system, need help
if any one has pictures of a good set up in a CRX please post
Old Nov 19, 2009 | 06:08 AM
fcm's Avatar
fcm
Old Fart
What do you have now?
Make and models of audio system you now have?
In a CRX you can easily get away with a single 10" sub. 94
Old Nov 19, 2009 | 10:07 AM
hb420's Avatar
A single 10 is plenty for a crx. If you are interested i'm selling a fiberglass box for a single 10 inch sub that's fits inside your spare tire. Excuse the mess i was in the middle of tearing everything out. Don't go to walmart seriously.
Old Nov 19, 2009 | 10:09 AM
kingoftroy1978's Avatar
like fcm said a small 10" sub goes far in a crx. If you want loud and boomy go with a ported box that is made to the specs of the sub. If you listen to rock and want a tighter bass go with a sealed box again made to the specs of the sub. Dont just throw a 10" sub in a 10" box get something that is made for the sub.
On all the equipment stick with a good brand. If you havent heard of it or it is just is and looks cheap its going to sound cheap. With car audio 95% of the time you get what you pay for.
An amplifier for the sub: get an amp that matches the subs rms rating and impedence (ohm load). make sure you get wiring that is adequate for the amp. stay away from walmart wiring its cheap in price for a reason.
you could easily throw in a sub box and amp and wires and call it a day for around $400 for actually decent equipment. just stay with good brands.
Old Nov 19, 2009 | 01:35 PM
edzy's Avatar
no offense but that looks shabby as hell
op we need to know budget and musical taste.
a good 10 in the right box will be plenty.
even a single 8 would be good
Old Nov 19, 2009 | 03:38 PM
dohcvtak's Avatar
speaking of crx... check out KRock459's setup.... its beautiful..
focal midbass, dynaudio mid range, dynaudio tweeters, another focal 6.5 in the rear and diamond audio 10 sub(guessing he replaced the jl..) and that was in may god knows what he have now :D
Old Nov 19, 2009 | 04:09 PM
19Accord97's Avatar
If you want a cheap and effective bass upgrade, just get a Bazooka tube. Then you dont need any external amp or whatnot or a box.
Old Nov 19, 2009 | 05:42 PM
hb420's Avatar
Why because the old carpet is starting to come off ? The box sits inside of a tire that gets pulled in and out of my hatch. Who cares what the carpet looks like when it's covered by a false floor? It sounds great and that's it's purpose not to look good when i don't even see it. lol
Old Nov 19, 2009 | 06:38 PM
fcm's Avatar
fcm
Old Fart
X2.
Is that two pieces of 1" MDF laminated together?
How many layers, [weight] of fiberglass? 94
Old Nov 19, 2009 | 07:01 PM
hb420's Avatar
Originally Posted by fcm
X2.
Yes it's two pieces sandwiched together, the lower piece is what the sub is mounted to. I used two layers and the box without the sub weighs about 7 pounds.
Old Nov 19, 2009 | 07:37 PM
fcm's Avatar
fcm
Old Fart
Sorry, I meant weight of the fiberglass cloth or mat you used? 94
Old Nov 19, 2009 | 07:42 PM
hb420's Avatar
That i forget the box is 6 years old
Old Nov 19, 2009 | 08:52 PM
edzy's Avatar
thought u just had it sitting like that..
Old Nov 20, 2009 | 01:34 AM
Maluko's Avatar
just roll a W7 in that little crx. lol.
Old Nov 24, 2009 | 01:41 PM
racebum's Avatar
like others have said even a single 8" if used the the correct box with a decent amp will blurr your vision when the bass hits and take up less space. the JL 8w7 or solobaric 8 both have a lot of output for their size. my favorite cheap amps right now are the phoenix gold xenon's, they are a great SQ amp with *****. a 400.1 or 600.1 on the sub and 100.2 on your highs would slam in a crx. the higher end mb quart, jl; or focal gear all would be good choices. if you go less expensive the JL VR stuff still sounds great as does the phoenix xenon mids and tweets but they are very difficult to find since they often sell around 100-150 a set
Old Nov 25, 2009 | 11:23 AM
Eric R's Avatar
I haven't seen a single 8" sub that blurr my vision yet..
Old Nov 26, 2009 | 04:11 PM
ALL4SPL's Avatar
DD Audio 2500 Series 8" in a ported or bandbass with 1500watts will blur your vision easy, especially in a CRX.
Old Nov 26, 2009 | 04:41 PM
dohcvtak's Avatar
dd makes some of the best woofers so im not surprise by the claim
davelarue
Jun 14, 2008 11:03 AM
Arbiter
Audio / Security / Video
10
Jan 10, 2008 07:39 PM
remoer
Dec 24, 2006 12:54 PM
d spamony
20
Apr 4, 2004 08:17 PM
GroundZer0 336
Aug 18, 2003 07:05 PM
