Mid bass vs. Sub
What exactly is a mid bass woofer?
If I read it correctly, the mid bass is exactly what how it's read. It's bass, but not that low, like subs that produces the lows. Mid bass helps bring out the bass and the vocals. But it's not ground pounding, like subs.
Question:
If the sub woofer create the lows, that the ear can't really hear, then what's the point of the sub.? If we want rich base, and quality of music, wouldn't mid bass woofers do a better job?
Question:
Well, most people accept the defining line between a mid-bass driver and a sub as being able to produce sub-60Hz frequencies cleanly and loudly (powerful without distortion). We can supposedly hear down to 20Hz (tho most people aren't that good), but we can all hear at least down to the 35Hz range if your ears are in decent condition. A mid-bass driver won't be able to hit that low a frequency at all, and the lowest frequencies they hit are not produced with perfect clarity or with very much strenght. Subs add the lower extension of frequencies that was a part of the music and mid-bass drivers just can't reproduce those frequencies well enough. I like using mid-bass drivers down to about 90Hz. From there, I let the sub take over since it does that job best. If you're concerned about response and crispness, then get a smaller sub that reacts quicker and maybe look into some metal cone (aluminum or titanium) subs for the added clarity. If you're not into boom, a good 8" (or even JL's 6.5" 6W0) is a perfect addition to complete the system. The point of a good audio system is for us to hear the music the way it was originally intended. Most music has frequencies going below 60Hz, so it's best to use drivers that can easily reproduce those frequencies best.
Thanks for the response.
I was advise to turn up the EQ settings on the 50hz. I have it at +12. The reason is to get more boom for rap/hip hop. That means I'm actually running at 62hz. Do you agree? The booms seem to be sharper to me.
Going back to understanding this. With the EQ setting of 62hz does that mean I lost the lows, and my sub is basically pretending to be a mid bass?
TIA
TIA
Question:
Question:
The subwoofer used to play frequencies in the 20Hz or higher depending on the enclosure design) and 90Hz or between 60Hz to 100Hz depending on the limitations of the next larger speaker, the midrange or midbass.
If you want an accurate sounding system, covering the entire audible bandwidth between 20Hz and 20kHz (as accurately as possible) you NEED a subwoofer. It is the only speaker which is designed for reproducing music in the 20Hz to 80 region. Subbass adds substance and creates a foundation for the music, regardless of what you listen to.....
Trust me on this one.... I played MB Quart tech support for 2 years.
[Modified by dc24me, 11:12 PM 7/20/2001]
TIA
TIA
Vp Special K
Audio / Security / Video
Nov 10, 2006 02:47 PM
