Sub Question
Old Mar 4, 2004 | 07:47 PM
IntegraBoy04's Avatar
Default Sub Question
What is the difference between 2 ohm, and 4 ohm? I was looking at getting a Rockford Fosgate HX2, and I have no idea what the differences would be. Also, what would be a good amp to run one of these? I want 1 12. And is there really a point in getting a Power over a Punch? Thanks.
Old Mar 4, 2004 | 08:12 PM
GAtegs's Avatar
Default Re: Sub Question (IntegraBoy04)
I have a RF Power 800.2 if you are interested.
Old Mar 4, 2004 | 08:43 PM
Default Re: Sub Question (a98tegLS)
Is that an amp? How much for it? And I still need answers.
Old Mar 5, 2004 | 06:50 PM
No help?
Old Mar 5, 2004 | 07:19 PM
Ricey McRicerton's Avatar
An Ohm is a measure of resistance. If you have an amp that can be run at a lower Ohmage(resistance) (dunno if that's a word or not ) you can make a sub louder at a given volume setting. Hope that's clear enough so you understand.
Old Mar 5, 2004 | 07:28 PM
Default Re: Sub Question (Ricey McRicerton)
So, is 2 ohm better than 4 ohm?
Old Mar 5, 2004 | 08:12 PM
snoochtodanooch's Avatar
2 ohm is better than 4 ohm if you amp is stable to 2 ohm. in theory, the lower resistance in turn allows more watts to be put to a speaker, allowing it to be louder. That is why in certain classes of audio competition people would be in the low wattage categories with really loud systems. THey had amps that were stable down to 1/2 an ohm and they would wire several speakers in parallel to get alot of sound. If you can, pick up a little electricians wiring book and read about it. it makes alot more sense that way.
Old Mar 6, 2004 | 03:46 AM
Default Re: Sub Question (snoochtodanooch)
So what kind of amp could handle 2 ohms?
Old Mar 6, 2004 | 05:26 AM
many and most new sub amps can handle 2 ohms. check with the manufacturer, its one of the basic stats they list. Like 200watts rms at 4 ohms and 350 watts rms at 2
freeagent
Audio / Security / Video
Jul 4, 2009 09:49 AM
chinkyx90
Mar 14, 2009 05:35 PM
deeweezy
May 19, 2004 04:23 PM
ilikemyaccord
May 5, 2003 08:29 AM
ItzTw
Apr 16, 2002 08:21 AM
