Memory on deck and time resets
Old Mar 4, 2002 | 08:44 AM
hmonglonertim's Avatar
Default Memory on deck and time resets
Thought I saw this posted before but I couldn't find it anywhere. Anyways, everything was fine until I installed a used cd player using a harness on my wifes 92 civic. Once the receiver was installed the parking/vallet light is on without the switch being on. So I installed the stock tape player back on and the lights are fine but the vechicle will not hold the memory (time/radio station). Thanks in advance.
[Modified by hmonglonertim, 5:45 PM 3/4/2002]
Old Mar 4, 2002 | 09:11 AM
STK B16's Avatar
Default Re: Memory on deck and time resets (hmonglonertim)
in this case reverse the red and yellow wires connections.. yellow is constant 12v wich holds memory and red is ignition 12v
Old Mar 5, 2002 | 06:56 AM
Default Re: Memory on deck and time resets (Json79)
Would this fix the time on the vechicle also?
Old Mar 5, 2002 | 08:44 AM
STK B16's Avatar
should. unless u blew out the fuses..
Old Mar 5, 2002 | 01:47 PM
thanks
Old Mar 6, 2002 | 12:16 AM
glock's Avatar
New User
If that doesn't work check your backup fuse under the hood, i think its a 7.5amp.
tyler100
Audio / Security / Video
Jan 5, 2008 02:39 PM
Takymoto
Aug 31, 2006 05:56 PM
Bone Stock
Aug 22, 2004 06:09 PM
damion911
Mar 3, 2004 11:14 AM
awall
Jun 11, 2002 07:49 PM
