CD player died...help me out...
Old Aug 15, 2004 | 09:31 PM
Bone Stock's Avatar
From: City of fakeJDMs but their vT3s HiT H3ll4 L0uD...., usa
Default CD player died...help me out...
ohkay, so here is the story. I got one of those blinking lights and i wanted to try it out in my car, but i wanted to use a switch so i can turn it on and off. So i had some neon lights at home that had the cig lighter thing. I cut that , and opened it up so i could put the wires together, but when i tryed to cut one wire it totally ripped from the root, so my friend put the 2 wires from the blinking light and conected it to one of the wires from the (neon light cig thing) and stuck it in the cig place. Next thing you know my Cd player turns off. I was like wtf, I checked all the fuses and its not the fuse. What can it be? Any help on this guys? Have you had this problem before? Please help me out.
_armEn
Old Aug 16, 2004 | 10:43 AM
Bone Stock's Avatar
Default Re: CD player died...help me out... (Bone Stock)
please some one...
Old Aug 16, 2004 | 11:16 AM
foshizllmynizl's Avatar
did you check ALL of the fuses or the ones you thought had to do with the cd player ... some times it might be the interior light fuse ... and did you check both ... under stearing wheel area and under the hood? ... and if not did you cross the wires by any chance?
Old Aug 16, 2004 | 04:35 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bone Stock &raquo;</TD></TR><TR><TD CLASS="quote">ohkay, so here is the story. I got one of those blinking lights and i wanted to try it out in my car, but i wanted to use a switch so i can turn it on and off. So i had some neon lights at home that had the cig lighter thing. I cut that , and opened it up so i could put the wires together, but when i tryed to cut one wire it totally ripped from the root, so my friend put the 2 wires from the blinking light and conected it to one of the wires from the (neon light cig thing) and stuck it in the cig place. Next thing you know my Cd player turns off. I was like wtf, I checked all the fuses and its not the fuse. What can it be? Any help on this guys? Have you had this problem before? Please help me out.
_armEn </TD></TR></TABLE>Check 7.5 amp fuse in engine bay fusebox, also you don't need a switch for the LED , the red wire gos to 12v+ conn. and the black wire gos to 12v+ acc., turn off the ign. the LED will blink, turn on the ign. the LED is off. 94
Old Aug 16, 2004 | 09:46 PM
LSP's Avatar
LSP
i have a feeling you might have blown the cig lighter fuse. Thats located under the dash.
Old Aug 16, 2004 | 09:56 PM
Bone Stock's Avatar
Default Re: CD player died...help me out... (LSP)
Thanks for all the responses guys, so none of you think its the Cdplayer.. thank god
I'm going to get my big *** light and take it downstairs and check everything you guys said.
And like ive said before...I LOVE H-T...
Old Aug 22, 2004 | 10:51 AM
TeamYelloHead's Avatar
this happen to meeh once. its the 7.5a fuse under the hood. but check the fuse on the cd player as well. there should be a fuse on the cd player near or behind the harness. that can be blown too.. good luck
Old Aug 22, 2004 | 06:09 PM
Bone Stock's Avatar
Default Re: CD player died...help me out... (TeamYelloHead)
Modified by Bone Stock at 11:00 PM 9/15/2004
tyler100
Audio / Security / Video
Jan 5, 2008 02:39 PM
EGgarniEG
May 30, 2007 02:02 PM
Techy
Jul 23, 2005 10:47 PM
Steezn4NOReason
Nov 23, 2004 11:28 PM
98integrah
Sep 28, 2003 01:21 PM
