Major help on selections of sounds!!!!!!!! <---------
Old Jun 25, 2002 | 11:23 PM
AznImage504's Avatar
Default Major help on selections of sounds!!!!!!!! <---------
i got a civic and i am pullin 2 subs that are 800 watt max and a 400 watt component set . Which is better to use for the sound system, a seperate battery or a cap??? And can u tell the differnences between both of them????
Old Jun 26, 2002 | 12:21 AM
DuNkiN's Avatar
New User
Default Re: Major help on selections of sounds!!!!!!!! <--------- (AznImage504)
i have both but it depends on if you need them or not. if your amp is drawing too much current, get a cap first, its cheaper and see if that solves the problem. if your lights still dim then its still drawing too much current so get the battery. thats what i did and was told.
Old Jun 26, 2002 | 10:28 AM
rcurley55's Avatar
New User
Default Re: Major help on selections of sounds!!!!!!!! <--------- (DuNkiN)
A second battery will do nothing to help your dimming solution, and it may actually make it worse. Use a second battery only if you plan on listening it to extended periods with the car off.
What's happening, is your alternator can't produce enough juice to support your amps. I would consider upgrading the underhood wiring, then try a cap. They are a bandaid, but my help in your situation.
Old Jun 27, 2002 | 04:17 PM
Hey,
Thanks for the advise man. What is the best cap out there to use for my civic? And which farad should i get?
Old Jun 28, 2002 | 08:24 AM
o_Rage_o's Avatar
400 watt components???
dear god, focal and infinity push 200watt, which components do you have??
if they are actually 400w clean, then your gonna nead a 1 farad cap and prob an alternator upgrade to push the system.
-Rage
Old Jul 4, 2002 | 12:02 PM
philly-O's Avatar
Default Re: Major help on selections of sounds!!!!!!!! <--------- (o_Rage_o)
pretty much all caps are the same because there are only a few companies that actually make them so as long as its a name brand you will be ok.
doubledee
Audio / Security / Video
Jul 30, 2008 12:15 AM
doubledee
Jul 27, 2008 02:43 PM
1.8gsrcivic2000
Jan 21, 2005 08:07 AM
adrianl211985
Jun 2, 2004 09:03 AM
Mike813
Oct 9, 2003 09:38 PM
