Line out converter question
Old May 3, 2006 | 08:47 AM
markturbo's Avatar
Default Line out converter question
I just picked up a line out converter (LOC) so I can run an amp to power a sub off my factory deck (00 Civic Si). From reading on this site I thought there would be only two wires for the signal, but this LOC has four wires to take the signal from both the front and rear speakers.
Can I use just the rear speakers for the signal? Would there be any advantage from using both the front and rear?
Thanks
Old May 3, 2006 | 10:35 AM
fcm's Avatar
fcm
Old Fart
Default Re: Line out converter question (markturbo)
The sub would be non fading if you take the signal from all 4 speakers, that would be the advantage. However are you sure they are not just a pos. (+) and neg. (-) for 2 speakers? 94
Old May 4, 2006 | 01:20 AM
EnjoyTheRideDC2's Avatar
Default Re: Line out converter question (fcm)
Only time I've seen an LOC with 4 speaker hookups would be a 4channel LOC.
Old May 4, 2006 | 03:53 AM
markturbo's Avatar
Default Re: Line out converter question (EnjoyTheRideDC2)
I had only looked at it quickly as I was on my lunch at the time, but you were right, there are only four wires...positive and negitive for the rear speakers.
I installed it last night along with the rest of the wiring kit, hooked up my girlfriends sub and amp to it just to test it and everything worked. It's all I need to give me more bass then stock and keep the clean factory look inside the car with the factory CD player.
toshko321
Audio / Security / Video
Jun 16, 2011 08:34 AM
Giggybobble
Oct 18, 2009 10:38 PM
Liquidgsr
Jul 16, 2008 09:04 AM
PatrickGSR94
Oct 22, 2004 12:37 PM
King_j
Aug 24, 2003 03:18 PM
