lights dimming with system
Old Aug 5, 2003 | 08:38 PM
ravi's Avatar
Default lights dimming with system
i just installed a new amp and new deck into my car and after installing the new i noticed that when i put the volume up on the deck i can notice the front headlights and rear brake lights and gauge cluster dim when the bass hits.
im using 10 gauge wiring battery to amp and the amp is a 900watt (max power) rockford, and sub is a 500watt mtx (1)
any ideas to fix this? i was thinking maybe changing the 10gaguge to a 4gauge wire
Old Aug 5, 2003 | 08:57 PM
Torridcivic's Avatar
Default Re: lights dimming with system (ravi)
Yeah, you need to change the wire, a $20 upgrade, and it might save you from buying a capacitor. The next step is the big 3 upgrade I did it, big difference, last two steps spending 100+ on a capacitor or new alternator, or battery.
Anything else?
Old Aug 5, 2003 | 09:06 PM
tegmech's Avatar
Purchasing a larger wire won't help your lights from dimming. All a larger wire is going to allow is for more current to flow through it. However in your case i would get it because a 10 gauge is way to small for a rockford 900 max. You will need to get a capacitor for the system. That is the cheapest and only correct fix for that unless you go with a larger alternator. Which if you don't fix this you will be go through alternators alot faster. hope this helps
Old Aug 5, 2003 | 09:33 PM
ravi's Avatar
Default Re: (tegmech)
i'll try upgrading the wire first...if that doesnt do it then i'll try the other two
could it have anythin to do with the fact im running stock speakers on a 200watt deck..
Old Aug 6, 2003 | 09:16 AM
J^M^'s Avatar
10 GAUGE FOR AN AMP!? i thought i was crazy!!!!!!!!!!!!!!!!!!!!!!!! you take the CAKE MANG!
///Nick
Audio / Security / Video
Aug 13, 2011 04:06 PM
96 EX
29
Mar 30, 2009 11:13 AM
Accord-Guy
18
Dec 13, 2007 03:19 PM
kevinoneill
21
Feb 29, 2004 09:58 PM
964dgsr
Nov 5, 2002 08:58 PM
