L5 sub problems.. help
Old Aug 9, 2006 | 04:35 AM
jdmtuner64's Avatar
Default L5 sub problems.. help
Ok well im using and l5 10' sub on a intersys 1200 watt mono amp and using critical mass wires
this what happened: sucky panasonic Head unit and um i was at volume 35 volume max hits 40 and so i was playing dirt off your shoulder and then all of a sudden i smell something bad and i saw in the back my box was smoking.. when i turned my music off and back on when i try hitting volume 25 my amp protects... can someone help me?? p.s. iam also using a capacitor and a crossover for the sub
Old Aug 9, 2006 | 05:43 AM
94_DC4's Avatar
Default Re: L5 sub problems.. help (jdmtuner64)
Did you charge the capacitor before you installed it?
Old Aug 9, 2006 | 07:41 AM
02 accord's Avatar
Does the amp not go into protect below vol. 25?
Disconnect all the sub wiring from the amp, and see if the amp turns on without going into protect mode. If it does, check the sub wiring, to make sure you don't have any shorts. If all else fails, your sub is cooked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRGDC &raquo;</TD></TR><TR><TD CLASS="quote">Did you charge the capacitor before you installed it?</TD></TR></TABLE>
What does that have to do with this? If he didn't charge it, he would most likely blow his fuse when he first hooked it up. I don't see how that would be related to this problem.
Old Aug 9, 2006 | 12:30 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: L5 sub problems.. help (02 accord)
v.c. damage is what happened The smoke you saw was the voice coil melting. the coating that was on it. The real stinky smell.
Old Aug 9, 2006 | 04:17 PM
fcm's Avatar
fcm
Old Fart
Default Re: L5 sub problems.. help (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">v.c. damage is what happened The smoke you saw was the voice coil melting. the coating that was on it. The real stinky smell. </TD></TR></TABLE> Ditto that, drove that amp into hard distortion, does the sub cone still move if you push it by hand? 94
Old Aug 21, 2006 | 04:01 AM
jdmtuner64's Avatar
Default Re: L5 sub problems.. help (fcm)
well um it is a really stinky smell is there any way i can get this sucker fixed?? um it doesnt go into protect under vol. 25
Old Aug 21, 2006 | 07:01 AM
You could try to send it to kicker. But they will figure it out that the sub was abused.
Old Aug 21, 2006 | 09:14 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">You could try to send it to kicker. But they will figure it out that the sub was abused.</TD></TR></TABLE> Ditto that, it was not the "sucky panasonic" that destroyed the sub, [burnt VCs] it was the amp, [intersys 1200 ???]
that wrecked the sub, for whatever reason, [driven too hard, poor power or ground, bad amp] amp output went DC, not good, and burnt the VCs, burnt VCs are not a warranty item, it is not a manufacturers defect, it is abuse. 94
JDMcivicSiEG6
Audio / Security / Video
Mar 12, 2008 09:02 PM
tomek5x
Jul 10, 2007 04:18 PM
Ef Whore
May 6, 2005 06:06 PM
Fuster_Cluck
Aug 8, 2003 05:57 PM
redteg1
Apr 9, 2002 08:47 PM
