kill switch wires under dash
Old Oct 18, 2012 | 03:55 PM
raverx3m's Avatar
Default kill switch wires under dash
what wires can i use under dash or from fuse box to wire up a kill switch
im looking for wires on driver side dash so i can hide them and make it look like stock wires
because most people already know to look around ecu harness for kill switches so its not very effective
Old Oct 18, 2012 | 10:41 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: kill switch wires under dash
There are so many circuits to do, grab a helms book and look it over, Its really not hard, just time consuming.
Old Oct 19, 2012 | 03:19 AM
NVturbo's Avatar
O.G. triple O.G.
black (GROUND) wires at the PGMFI relay....
Old Oct 19, 2012 | 08:28 AM
raverx3m's Avatar
I already tried few
Which ones actually dosable stuff
Old Oct 19, 2012 | 03:49 PM
What does a car need to run? fuel, injectors, ecu, crank sensors, map, tps, Thats just to name a few.
Old Oct 19, 2012 | 04:41 PM
raverx3m's Avatar
Damn people cant read.
Which ones are under driver dash or around fuse box
NOT IN THE ENGINE BAY OR PASS SIDE.
I tried disconnecting some wires from fusebox but they didnt do anything
Old Oct 19, 2012 | 07:30 PM
Well since I can't read, Those wires are in the car. Good luck to ya.
Old Oct 20, 2012 | 07:20 AM
raverx3m's Avatar
Great help bro. Maybe if you told me where they are i wouldnt be a dick.
Wires are in the car... that helps alot.
Old Oct 20, 2012 | 04:49 PM
Salami's Avatar
You are correct, you can't read!!
Use a Helms like you were told before and you find the wires you are looking for. The entire wiring system of the car is spelled out for you in the Helms service manual.
You respond with a bad attitude and you expect to people to help you out? Shot your self in the foot on this one buddy.
Old Oct 20, 2012 | 06:12 PM
raverx3m's Avatar
I dont have acess to a manual at the moment or a pc because we are buying a house and all my sht is in storage im using my cellphone which is not the best pdf reader.
Is it really that hard to write which wires run underdash?
If i had a manial i wouldnt be asking here since there are plenty of smartasses that are quick with stupid replies like the ones above but when asked dont really know the answer themselves.
Old Oct 20, 2012 | 07:49 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
This might help find a wire
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/unknown-plug-shares-yellow-wire-c922-ignition-switch-plug-dash-fuse-box-3085084/
Main relay is another
Old Oct 21, 2012 | 08:51 AM
NVturbo's Avatar
O.G. triple O.G.
NO, YOU CAN'T READ. I ALREADY TOLD YOU THE WIRE AND LOCATION. Besides, your dumbass didn't even mention what model car you had. For all we know, you might be driving around in a Prius.
Old Oct 22, 2012 | 12:01 AM
BrotherAli's Avatar
http://www.civic-eg.com/causeforalar...kill/index.php
Old Oct 22, 2012 | 10:34 PM
Doing this for the car, Look at the harness on driver side, Follow that harness into the car and get all the way up there. yellow wire with black strip.
r1ch
Audio / Security / Video
Dec 14, 2006 12:48 AM
ragejed
Nov 11, 2003 01:20 PM
hagrid
Jan 8, 2003 01:22 PM
