kill switch
Old May 15, 2008 | 10:47 PM
beastman@'s Avatar
Default simple kill switch
I know the general rule for a simple kill switch is the extension can't be more than 5 feet.
Does this mean keep it under two 2.5' extensions totaling 5', or two 5' extensions?
I'm just trying to think of where I'll put mine, and if I need a relay.
Old May 16, 2008 | 01:28 AM
cowteg's Avatar
Default Re: simple kill switch (beastman@)
Why can't the extension be more than 5 feet?
Old May 16, 2008 | 04:12 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
what kind of kill switch?
Old May 16, 2008 | 08:54 AM
beastman@'s Avatar
Default Re: simple kill switch (wrx-killer-Sti-eater)
Fuel pump kill. I wanted to do the simple one (ver.1) but I'm not sure about placement yet.
Old May 16, 2008 | 09:24 PM
cowteg's Avatar
I still don't see why you can't have more than a 5 feet extension.
Old May 16, 2008 | 11:45 PM
tazeat's Avatar
Default Re: simple kill switch (cowteg)
Well you can, but I'd go with a thicker wire just to be safe... I'd do at least 12 gauge and make sure your connections are solid good luck.
Old May 17, 2008 | 12:41 AM
suspendedHatch's Avatar
Default Re: simple kill switch (tazeat)
The longer the wire, the more the resistance. I pulled that 5 ft figure out of my rear end though.
Total.
Resistance on the fuel pump wire will effect your fuel system.
fcm recommends you put the kill switch on the main relay.
Old May 17, 2008 | 01:05 AM
cowteg's Avatar
Default Re: simple kill switch (suspendedHatch)
The stock fuel pump wire is pretty long already. Here's a random site I found: http://www.proav.de/index.html....html
It lists wire resistances per 1000'. An 18 gauge wire for example has 6.6 ohms of resistance per 1000 feet. That means 5 feet of 18 gauge wire is 0.033 ohms. Pretty small....
Ldo
10
Feb 24, 2009 05:15 PM
96electronH
Audio / Security / Video
Dec 2, 2007 05:29 PM
99fbpem1
Aug 19, 2007 04:23 PM
1989CivicSi
Dec 28, 2005 02:04 AM
96tegsr
Feb 6, 2003 08:01 AM
