keyless entry issues
Old Apr 5, 2007 | 08:46 AM
rcar97's Avatar
Default keyless entry issues
OK, I've programmed my remotes and the d/l actuated which is suppose to signal that the remote is programmed. When I try to open the door or anything with the remote nothing happens. Please help..Thanks
Old Apr 5, 2007 | 10:23 AM
jz98ctr's Avatar
need more info mister vague!!!
car/make/model....make and model of alarm ...let's start from there
Old Apr 5, 2007 | 02:04 PM
rcar97's Avatar
Default Re: keyless entry issues (rcar97)
Sorry, Its a 1999 Acura 1.6el 4 door with the d16y8 motor.
They are almost exactly the same as a 1999 civic but badged Acura in Canada.
When I first got the car the keyless worked OK. Recently it stopped working. I thought it was the remote so I changed the battery and reprogrammed it. Went through the sequence and had the door locks cycle on and off to confirm that the remote was programmed. I then get out of the car and push the unlock or lock and nothing happens. Could it be the module? Is it located by the steering wheel? Any help is greatly appreciated
Old Apr 5, 2007 | 08:47 PM
fcm's Avatar
fcm
Old Fart
Is this a stock key-less entry system?
If so , do the door locks work properly without the remote?
If so, I would say its the key-less entry module, drivers kick panel, [white]. 94
Old Apr 9, 2007 | 09:50 AM
rcar97's Avatar
Default Re: keyless entry issues (fcm)
Its a 1999 stock keyless entry systen
Old Apr 9, 2007 | 11:33 AM
fcm's Avatar
fcm
Old Fart
Then my guess is the door lock module is N/G, it is receiving the RF signal from the remote, just not from the RF section to the door lock control section. 94
Old Apr 9, 2007 | 12:19 PM
rcar97's Avatar
Thanks dude, I need to check/test the module. On els or civics it under the seat right?
Old Apr 9, 2007 | 04:08 PM
fcm's Avatar
fcm
Old Fart
Key -less entry module is white and behind drivers side kick panel. 94
Old Apr 10, 2007 | 08:56 AM
rcar97's Avatar
Thank you sir!
BrianB16A2
Dec 1, 2013 11:23 AM
John Wilson
Audio / Security / Video
Sep 2, 2013 09:58 PM
94trouble
20
Oct 4, 2011 04:55 AM
importdude2000
12
Jun 20, 2011 06:54 PM
