keyless entry for CRX
Old Sep 11, 2005 | 12:55 PM
nudvl's Avatar
Default keyless entry for CRX
What is everyone or anyone using for a keyless entry on a crx/ef ??? I plan on installing a aftermarket car alarm but i want a keyless as well since im doing away with the door locks. any ideas
Old Sep 11, 2005 | 03:47 PM
nudvl's Avatar
ttt
Old Sep 11, 2005 | 05:49 PM
nudvl's Avatar
anyone
Old Sep 12, 2005 | 02:50 PM
nudvl's Avatar
come on i know sumone is usin a aftermarket keyless on a car that come factory with it.
Old Sep 13, 2005 | 01:05 PM
fcm's Avatar
fcm
Old Fart
Default Re: (nudvl)
There are so many D/L systems out there, you can get a good D/L actuator for less then $10 and relays, [if you need them] for about $2, if you want a good setup take a look at Spal http://www.spal.com/automotive...m.htm the best I have installed. 94
Old Sep 13, 2005 | 04:02 PM
nudvl's Avatar
cool man thanks for the info. and i assume u can hook them up to car alarms as well.
Old Sep 13, 2005 | 05:07 PM
fcm's Avatar
fcm
Old Fart
Default Re: (nudvl)
Yes you can, the one I link you to is a "central" D/L system, the module will have neg. triggered inputs, so when you arm the alarm the doors will lock, and when you disarm the alarm they will unlock, if the alarm has "programmable" D/Ls you can have ign. controlled D/L, and because the actuators have switch's in them, your manual door lock "buttons", [the ones you have in the car now] become "power D/L buttons" locking one door will also lock the other door. If you want to go the less expensive way, then all you need is 2 actuators and 2 relays wired this way http://www.the12volt.com/doorlocks/page3.asp#arp the alarm becomes the control module. 94
Old Sep 18, 2005 | 01:41 PM
incubus's Avatar
Default Re: (fcm)
i second that spal makes good product, they have power window kits too if u want to do them also.
I have spal actuators in my CRX, work like a charm.
Old Sep 19, 2005 | 12:17 PM
customgsr's Avatar
Default Re: keyless entry for CRX (nudvl)
it will work on it with no problems.
Old Oct 12, 2005 | 06:55 AM
SRCRX's Avatar
also look for any DEI products (viper) all of there alarms, stand up to the time of time. the p/n on the doorlock acc. is a 524n
Old Oct 12, 2005 | 08:39 AM
db8xc1x39
Guest
Posts: n/a
Default Re: keyless entry for CRX (SRCRX)
DEI all the way...they giv eyou everything you need to custom mount it anywhere.
JDMPLEASE
Honda Civic (2001 - 2005)
21
Jul 25, 2007 05:52 PM
nsxxtreme
Audio / Security / Video
19
Aug 29, 2006 07:53 AM
ochdog
May 24, 2004 02:40 PM
sloweredcivic
Jan 17, 2004 10:48 PM
