JL audio slash series 300/4 Amp...... low ohms light on!
Old Fart
Re: JL audio slash series 300/4 Amp...... low ohms light on! (aznwash3wboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznwash3wboi »</TD></TR><TR><TD CLASS="quote">the low ohms light is on..... any ideas? probably short somewhere?</TD></TR></TABLE> or a burnt VC, try disconnecting the speakers, at the amp, and checking the impedance and for a short, with a multimeter, if you don't have a meter, try disconnecting the speakers one at a time, and then reconnecting them one at a time, [starting with the first one you disconnected] 94
Re: JL audio slash series 300/4 Amp...... low ohms light on! (fcm)
i checked all the speaker wires, disconnected from the amp side, and they all read around 4ohms.... they seem fine.... but the RR speaker turns off and on...im thinkin that the speaker is bad...ill replace it cuz i got another one layin around....hopefully that will solve the problem....
Old Fart
Did you try and hook up the other speakers to the amp and see if it worked, also if the speaker cuts out it may not be the speaker, it may be an intermittent short in the wiring 94
