Amp Overcurrent Problem when Volume is up
Old Nov 17, 2010 | 03:51 PM
headrec*'s Avatar
Default Amp Overcurrent Problem when Volume is up
Hey
I have a sony xplode amp. Its an piece of junk but I had it kicking around. Hooked the subwoofer and the amp. Everything works great until I turn it up then the amp trips out and stops powering the sub. If I turn off the deck and back on it works fine...until I turn it up again. The light that comes on when it stops working says its an 'overcurrent' problem
I've tried it with two separate subwoofers and had the same problem. Its a 760 watt amp and I bought a wiring kit rated up to 1000 watts. So would this mean the amp is junk or ?
Old Nov 17, 2010 | 04:13 PM
joeymc13's Avatar
Default Re: Amp Overcurrent Problem when Volume is up
Check the ground on the amp... It should be as short as possible and securely mounted to metal in the car with the paint cleaned off.
Old Nov 17, 2010 | 04:35 PM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^.
What is the model of the amp?
What is the make and model of the subs you have connected the amp to?
The over current light will come on if a sub is blow, [VC damaged] or if the load, [impedance] is too low, either way, damaged VC or low impedance would result in your symptoms, works until you turn it up. 94
Old Nov 17, 2010 | 04:54 PM
Cobb2819's Avatar
this is the same thing i was thinking, until i read he tried it with 2 different subs, then i was thinking more along the second part about impedance.
Old Nov 17, 2010 | 05:17 PM
joeymc13's Avatar
Well, if its an impedence problem, OP, we need you to post the model of the amp (as fcm stated), along with the model of the sub. If the subs you've tried are dual voice coil, how did you wire them?
Sean Juan
Audio / Security / Video
Sep 8, 2005 11:30 AM
numbnuts22715
May 7, 2005 06:39 PM
ringooo
17
Apr 6, 2004 09:21 PM
Feuerraeder
Dec 24, 2002 09:06 AM
