Integra Parking Lights Wire?
Old Oct 4, 2002 | 02:00 PM
integra-modder's Avatar
Default Integra Parking Lights Wire?
Anyone know where to find the black/red parking lights wire that is AFTER the under dash fuse?
Old Oct 4, 2002 | 06:41 PM
Default Re: Integra Parking Lights Wire? (integra-modder)
ttt
Old Oct 4, 2002 | 08:48 PM
ichibanjap's Avatar
What exactly are you trying to hook up to it?
Old Oct 4, 2002 | 08:55 PM
philly-O's Avatar
Default Re: Integra Parking Lights Wire? (ichibanjap)
you should be able to plug directly into the front of the fuse box. there are like 6 open spots across the top of the fuse box and the one for the parking lights is just past the right side of center. you can use a female speaker terminal to slide over it.
Old Oct 4, 2002 | 09:15 PM
audioroach's Avatar
You still trying to get your alarm done....what is it now day 10 and counting...i admire you for your drive but I really think you should have started out small and worked your way up...I wish you all the best on that project.
Old Oct 5, 2002 | 12:18 AM
incubus's Avatar
Default Re: Integra Parking Lights Wire? (audioroach)
go to the library and get a haynes or something out, thats what i did.
Old Oct 5, 2002 | 06:03 AM
yes, I found out yesterday that the way I have it hooked up, through pin #2 from the left of the fuse box (which someone above suggested), that when I arm it and the lights flash, it also sends a pulse through the ignition, thus causing the AG4 to think that the car is being starting and making it go off.
when you turn on the lights, you can hear a relay click over on the AG4, and after you turn them off, it clicks over again followed by a short single chirp.
This is why I need to find the wire that just goes to the bulbs themseves so that it doesnt flow through the ignition in any way.
go to the library and get a haynes or something out, thats what I did.
Hayes are absolutely useless, I have one, then I got smart and bought a Helms.
[Modified by integra-modder, 10:04 AM 10/5/2002]
Old Oct 5, 2002 | 10:44 AM
audioroach's Avatar
The male plug in the fuse box ( if memory serves me right)...is only tied into the park light circuit..if your are getting feedback through to the ignition circuit..then quite possibly its an error made in the wiring. Now is the time to step back take a deep breath....undo all the wiring......get a new harness and start over.
Old Oct 5, 2002 | 05:01 PM
hahahahah
you're funny
hahahhaha
anyway, today i disconnected the wiring from the red/green wire and screwd around with some other wiring and got it to work, but my RS still doesnt work, but thats another issue...
Old Oct 6, 2002 | 07:28 AM
audioroach's Avatar
hahahahah
you're funny
hahahhaha
You laugh...I was being serious....I understand that you put in the bench time..but there comes a time when you must realize that you are over your head and that you must step back...regroup and start over. If not you may be destined to spend more time troubleshooting than enjoying the fruits of your labor. Just a few choice words of advice...but the final choice is yours to make alone.
Old Oct 6, 2002 | 08:15 AM
philly-O's Avatar
this is the unwanted truth...unfortunately it is true and will take less time in the long run. plus it will be a tool that you will gain in future problems similar to this one. once again i will wish you luck
Old Oct 6, 2002 | 09:36 AM
Default Re: Integra Parking Lights Wire? (peichie)
thanks, but i now just gatta figure out why the RS isnt working...the rest is working perfectly
c4ptiv3
Jan 27, 2011 11:07 AM
blackakkord
Jan 31, 2008 05:46 PM
EM1VtecSi
13
Mar 4, 2005 01:10 PM
RacerMike
Dec 2, 2004 04:40 PM
integra-modder
Oct 5, 2002 06:05 AM
