integra door speaker install question.
Old Feb 26, 2006 | 03:14 PM
sinister357's Avatar
Default integra door speaker install question.
did you need to remove the "basket" or did you put it in without clearance problem. i might have to remove mine for some mb quart.
Old Feb 26, 2006 | 03:39 PM
fcm's Avatar
fcm
Old Fart
Default Re: integra door speaker install question. (sinister357)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister357 &raquo;</TD></TR><TR><TD CLASS="quote">did you need to remove the "basket" or did you put it in without clearance problem. i might have to remove mine for some mb quart.</TD></TR></TABLE>What size MB Quart, model number?
If the speakers will fit the 5" mounting hole then you can cut the back out of the oem speaker housing and gain some more depth or a "depth reducer" or spacer can be used, or a combination of both, if the speaker will not fit the oem speaker housing with the above mod's then you will have to replace them with custom speaker mounts, I use MDF.
If you remove the speaker housing and try and just mount the speaker to the door, you are not going to get a seal, and the speakers will sound like ****. 94
Old Feb 27, 2006 | 06:14 AM
Default Re: integra door speaker install question. (fcm)
they are Quart QM160KX 6 ½”. so a i inch spacer has to be made huh? did you use the original as a template or how did you do it?
Old Feb 27, 2006 | 12:20 PM
fcm's Avatar
fcm
Old Fart
Sorry I can't find any info on the speakers, so I don't know it's mounting hole diameter or it's mounting depth, the stock speaker has a 5" mounting hole diameter and less the a 2" mounting depth, there is about an inch of extra depth if you cut the back of the speaker housing out, and you can "space" the speaker out about 1", [1" spacer] you can use the "spacer'" if the speaker mounting hole diameter is 5" - 5 3/16", any bigger the that and you will not be able to mount the spacer ring to the oem housing properly.
A spacer ring is nothing more then a MDF ring that is the thickness you need with an inside diameter the same as the speakers mounting hole diameter and an outside diameter the same as speakers overall diameter. 94
deerman2701
Audio / Security / Video
Jan 1, 2008 06:27 AM
Team PHATBOYZ
Nov 17, 2005 01:38 PM
colslaw87
Sep 27, 2004 01:02 PM
Dirt
12
May 6, 2002 07:02 AM
