Speaker Install
Old Dec 31, 2007 | 07:32 PM
deerman2701's Avatar
Default Speaker Install
I have a 99 Honda Civic LX sedan car, I just installed a new head unit. Next step I want to do is replacing the front speaker's. My question is do I have to remove the whole door panel, or can I use a flat screw driver and pop the plastic cover off the OEM speaker? There is a little spot for a screw driver it looks like but I don't want to break the plastic, thanks.
And also what about the rear speakers? I heard in some cases you have to remove the seats? Or can you just pop the trunk and remove the screws, pop the cover inside the car that covers the OEM speakers, then remove the screws holding the OEM speaker in? Thanks.
Old Dec 31, 2007 | 07:36 PM
B18C_EJ8's Avatar
Front speakers are easy. You don't even need a screwdriver to get the grilles off. Just use your fingers & pry them off.
On the Sedan, you don't need to pull the rear deck to get the speakers out like on the 2 doors. Simply lay in the trunk looking up, and you'll be able to unscrew the grilles from underneath.
Old Dec 31, 2007 | 07:59 PM
Default Re: Speaker Install (deerman2701)
Thanks, is there any connectors I have to get when I go to best buy and get the speakers?
Old Jan 1, 2008 | 06:27 AM
B18C_EJ8's Avatar
Yes. Two pairs of speaker harnesses. Will make installation plug & play.
Just tell them what kind of car you have and they'll get the right ones for you. The part number escapes me right now.
acmoc
Jan 26, 2008 03:03 PM
deerman2701
Dec 31, 2007 09:56 PM
EvenStar
Feb 17, 2007 06:04 PM
bamelto
Audio / Security / Video
Oct 6, 2004 07:52 AM
