integra amp wiring
Old May 5, 2002 | 09:13 PM
94civicx's Avatar
New User
Default integra amp wiring
I think I know the answer but what is the best way to wire an power cable from the battery all the way to the hatch part on my teg. It is easiest to go down the right running board or where?
Old May 5, 2002 | 10:57 PM
Slain's Avatar
Default Re: integra amp wiring (94civicx)
my freind wired his through the firewall on his driverside and went down the left side of the car.... you will need a bit more pwr cable this way since u have to leave some slack inorder to reach the battery.
Old May 6, 2002 | 07:17 AM
GSRaCeRbOI's Avatar
I wired my power wires from the battery, into the firewall, into the cabin, under the panels on the door, into the panel in the rear quarter panel, and out to the trunk.... for the speaker wires.. i wired it like this but on the drivers side.. and in the center console/tranny tunnel is where i ran my AI-Net/changer cables... I get no noise from my system.. make sure you get a good clean/bare metal ground too.. couple w/ separated wiring.. you should be aight...
Old May 6, 2002 | 08:36 AM
94civicx's Avatar
New User
Default Re: integra amp wiring (GSRaCeRbOI)
thanks. when you say under the panels on the door, do you mean the plastic running boards and how did you lift them up.
91hatchproject
Mar 19, 2010 03:01 AM
tsouyporta
Audio / Security / Video
Jul 7, 2006 09:48 AM
noob with an RS
Jan 5, 2005 08:25 AM
uAiNtSoOkOoL
Dec 3, 2004 08:30 PM
CompactRacerX
Apr 24, 2003 03:20 PM
