System wiring
Old Jan 3, 2005 | 11:59 PM
noob with an RS's Avatar
Default System wiring
im going to be taking out the seats and the necessary portions of my carpet out of my 2DR 94 Integra this friday and am going to install a pair of 6.5" components and an amp to power it. what im wondering is how exactly is the best way to run each wire. i would like EVERYONES opinion on this please.
Should i have each speaker run through the door sils? (i.e. <U>left</U> speaker running through <U>LEFT</U> door sil then through 'door jamb hole' to component box.. and <U>RIGHT</U> speaker <U>through</U> RIGHT and so on..)
Or should i run both speaker wires (L/R) down the middle console then have them split up behind the head unit to go to their speakers?
should i run the RCA wire down the middle through the center console? or run it through the door sil? if so, which door sil? is the POSITIVE power wire the only wire that will cause noise interference with RCAs?? what abount ground and speaker wires?
and are power and ground wires ok to run side by side each other? and should they be run through door sils or down the middle under center console?
please give me tips its going down friday!
Old Jan 4, 2005 | 08:44 AM
fcm's Avatar
fcm
Old Fart
Default Re: System wiring (noob with an RS)
Hint , keep all wires and cables as short as possable, keed RCAs away from ANY power wires, [center of car is best] run power down batt. side of car, under door sil, grounds should be as close to amp as possable, no need to run them anyplace other then to the floorpan. 94
Old Jan 4, 2005 | 09:11 AM
oh yea!! what was i thinking.. ground doesnt need to be run anywhere. thanks fcm. but one more thing.. you left out the components' speaker wires.. how should i run them?? they are going to be coming from the trunk to the doors.. would using each door sil for each speaker use less speaker wire than runnning it down the middle?
Old Jan 5, 2005 | 08:25 AM
fcm's Avatar
fcm
Old Fart
Default Re: (noob with an RS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noob with an RS &raquo;</TD></TR><TR><TD CLASS="quote">oh yea!! what was i thinking.. ground doesnt need to be run anywhere. thanks fcm. but one more thing.. you left out the components' speaker wires.. how should i run them?? they are going to be coming from the trunk to the doors.. would using each door sil for each speaker use less speaker wire than runnning it down the middle?</TD></TR></TABLE>It will be about the same. as you will still have to run the wire to the front and then to each door, it may be a little shorter to run them under the door sils, but not by more then a few inchs. 94
goldsy
Honda CR-V & Element
Jan 5, 2014 11:33 AM
gunnerman
Audio / Security / Video
Apr 8, 2009 09:34 AM
pez1
Apr 11, 2006 09:22 AM
AK94GSR
Jul 10, 2002 11:43 AM
kepani
Jun 3, 2001 05:18 AM
