installing valentine 1 direct-wire in integra
Old May 8, 2002 | 03:24 PM
zrx168's Avatar
Default installing valentine 1 direct-wire in integra
does anyone know if there is any guide on how to install direct-wire for valentine 1 in integra?
tia
Old May 9, 2002 | 06:01 AM
BlackAckeR's Avatar
Default Re: installing valentine 1 direct-wire in integra (zrx168)
Brand new, it comes with a lighter adapter <u>and</u> the wiring for a direct connection. I hooked the direct connect up to the fuse block and ran the wire up and under the A pillar cover so it's not seen. If you're looking for the pinout to the RJ11(?) connector the V1 uses, I can't help with that...
Old May 9, 2002 | 09:16 AM
integra-modder's Avatar
Default Re: installing valentine 1 direct-wire in integra (BlackAckeR)
i did a temp install to above the glove box (thats where i hide the radar in ghetto areas)
Old May 9, 2002 | 02:54 PM
krshultz's Avatar
It's fairly straightforward once you have the parts in front of you. You need to find a good ground (IIRC there's one behind the stereo) and a key-on hot wire. The splicing thing that the kit comes with just clamps onto the hot wire and the ground, well, you ground it.
After that it's all a matter of where you put it and how you run the cables. The plastic around the windshield is relatively easy to remove, so you could run the cables through that.
BTW - the remote display unit gets a from me.
--Karl, who has his V1 hardwired into the tow vehicle
'91DA
Nov 20, 2008 11:38 AM
djmyst305
Apr 4, 2008 05:59 PM
dly11
Audio / Security / Video
Mar 17, 2008 09:07 PM
gsrjrsc
Mar 20, 2006 02:30 PM
letsstophere
Jan 5, 2006 10:20 AM
